And hereby the debug log when starting the movie (bad audio):
00:55:28.288 T:4110807040 DEBUG: Loading settings for nfs://10.0.0.1/The.Invisible.Guest.mkv
00:55:28.300 T:4110807040 DEBUG: CPlayerCoreFactory::GetPlayers(nfs://10.0.0.1/The.Invisible.Guest.mkv)
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
00:55:28.301 T:4110807040 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
00:55:28.301 T:4110807040 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
00:55:28.301 T:4110807040 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (VideoPlayer)
00:55:28.301 T:4110807040 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
00:55:28.301 T:4110807040 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
00:55:28.303 T:4110807040 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
00:55:28.306 T:4110807040 DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData
00:55:28.307 T:4110807040 NOTICE: VideoPlayer: Opening: nfs://10.0.0.1/The.Invisible.Guest.mkv
00:55:28.307 T:4110807040 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
00:55:28.307 T:4110807040 DEBUG: LinuxRendererGL: Cleaning up GL resources
00:55:28.307 T:3527873520 DEBUG: Thread VideoPlayer start, auto delete: false
00:55:28.307 T:3527873520 NOTICE: Creating InputStream
00:55:28.310 T:3527873520 DEBUG: SECTION:LoadDLL(libnfs.so.8)
00:55:28.311 T:3527873520 DEBUG: Loading: libnfs.so.8
00:55:28.345 T:3527873520 DEBUG: NFS: Context for 10.0.0.1/media not open - get a new context.
00:55:28.411 T:3527873520 DEBUG: NFS: Connected to server 10.0.0.1 and export /media
00:55:28.411 T:3527873520 DEBUG: NFS: chunks: r/w 1048576/1048576
00:55:28.459 T:3527873520 DEBUG: CNFSFile::Open - opened The.Invisible.Guest.mkv
00:55:28.478 T:3527873520 DEBUG: ScanForExternalSubtitles: Searching for subtitles...
00:55:28.489 T:3527873520 DEBUG: ScanForExternalSubtitles: END (total time: 11 ms)
00:55:28.489 T:3527873520 NOTICE: Creating Demuxer
00:55:28.500 T:3527873520 DEBUG: Open - probing detected format [matroska,webm]
00:55:28.506 T:3527873520 DEBUG: Open - avformat_find_stream_info starting
00:55:28.566 T:3527873520 DEBUG: Open - av_find_stream_info finished
00:55:28.566 T:3527873520 INFO: ffmpeg[D24713F0]: Input #0, matroska,webm, nfs://10.0.0.1/The.Invisible.Guest.mk':
00:55:28.566 T:3527873520 INFO: ffmpeg[D24713F0]: Metadata:
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: encoder : libebml v1.3.1 + libmatroska v1.4.2
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: creation_time : 2017-05-05 13:44:54
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: Duration: 01:46:20.04, start: 0.000000, bitrate: 11769 kb/s
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:0: start 0.000000, end 175.175000
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: Metadata:
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: title : 00:00:00.000
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:1: start 175.175000, end 798.339000
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: title : 00:02:55.175
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:2: start 798.339000, end 1423.839000
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: title : 00:13:18.339
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:3: start 1423.839000, end 1803.385000
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: title : 00:23:43.839
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:4: start 1803.385000, end 2298.755000
00:55:28.567 T:3527873520 INFO: ffmpeg[D24713F0]: title : 00:30:03.385
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:5: start 2298.755000, end 2883.798000
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: Metadata:
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: title : 00:38:18.755
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:6: start 2883.798000, end 3153.942000
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: title : 00:48:03.798
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:7: start 3153.942000, end 3623.370000
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: title : 00:52:33.942
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:8: start 3623.370000, end 4251.122000
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: title : 01:00:23.370
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:9: start 4251.122000, end 4690.811000
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: title : 01:10:51.122
00:55:28.568 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:10: start 4690.811000, end 5114.818000
00:55:28.569 T:3527873520 INFO: ffmpeg[D24713F0]: title : 01:18:10.811
00:55:28.569 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:11: start 5114.818000, end 5576.529000
00:55:28.569 T:3527873520 INFO: ffmpeg[D24713F0]: Metadata:
00:55:28.569 T:3527873520 INFO: ffmpeg[D24713F0]: title : 01:25:14.818
00:55:28.569 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:12: start 5576.529000, end 6087.039000
00:55:28.569 T:3527873520 INFO: ffmpeg[D24713F0]: title : 01:32:56.529
00:55:28.569 T:3527873520 INFO: ffmpeg[D24713F0]: Chapter #0:13: start 6087.039000, end 6380.040000
00:55:28.569 T:3527873520 INFO: ffmpeg[D24713F0]: title : 01:41:27.039
00:55:28.569 T:3527873520 INFO: ffmpeg[D24713F0]: Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x808 [SAR 1:1 DAR 240:101], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
00:55:28.569 T:3527873520 INFO: ffmpeg[D24713F0]: BPS : 8707015
00:55:28.569 T:3527873520 INFO: ffmpeg[D24713F0]: BPS-eng : 8707015
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: DURATION : 01:46:19.999000000
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: DURATION-eng : 01:46:19.999000000
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_FRAMES: 152967
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_FRAMES-eng: 152967
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_BYTES : 6943844048
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_BYTES-eng: 6943844048
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_APP: mkvmerge v8.3.0 ('Over the Horizon') 64bit
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_APP-eng: mkvmerge v8.3.0 ('Over the Horizon') 64bit
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_DATE_UTC: 2017-05-05 13:44:54
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_DATE_UTC-eng: 2017-05-05 13:44:54
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: Stream #0:1(spa): Audio: flac, 48000 Hz, 5.1(side), s32 (24 bit) (default)
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: Metadata:
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: BPS : 3060109
00:55:28.570 T:3527873520 INFO: ffmpeg[D24713F0]: BPS-eng : 3060109
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: DURATION : 01:46:20.040000000
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: DURATION-eng : 01:46:20.040000000
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_FRAMES: 74767
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_FRAMES-eng: 74767
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_BYTES : 2440452534
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_BYTES-eng: 2440452534
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_APP: mkvmerge v8.3.0 ('Over the Horizon') 64bit
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_APP-eng: mkvmerge v8.3.0 ('Over the Horizon') 64bit
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_DATE_UTC: 2017-05-05 13:44:54
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_DATE_UTC-eng: 2017-05-05 13:44:54
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: Stream #0:2(eng): Subtitle: subrip (default) (forced)
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: Metadata:
00:55:28.571 T:3527873520 INFO: ffmpeg[D24713F0]: title : forced
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: BPS : 58
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: BPS-eng : 58
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: DURATION : 01:39:33.676000000
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: DURATION-eng : 01:39:33.676000000
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_FRAMES: 1227
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_FRAMES-eng: 1227
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_BYTES : 43699
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: NUMBER_OF_BYTES-eng: 43699
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_APP: mkvmerge v8.3.0 ('Over the Horizon') 64bit
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_APP-eng: mkvmerge v8.3.0 ('Over the Horizon') 64bit
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_DATE_UTC: 2017-05-05 13:44:54
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_WRITING_DATE_UTC-eng: 2017-05-05 13:44:54
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
00:55:28.572 T:3527873520 INFO: ffmpeg[D24713F0]: _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
00:55:28.573 T:3527873520 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 0
00:55:28.573 T:3527873520 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 1
00:55:28.573 T:3527873520 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 2
00:55:28.573 T:3527873520 NOTICE: Opening stream: 0 source: 256
00:55:28.573 T:3527873520 NOTICE: Creating video codec with codec id: 28
00:55:28.573 T:3527873520 DEBUG: FactoryCodec - Video: amcodec - Opening
00:55:28.573 T:3527873520 INFO: CBitstreamConverter::Open bitstream to annexb init
00:55:28.573 T:3527873520 DEBUG: SECTION:LoadDLL(libamplayer.so)
00:55:28.575 T:3527873520 DEBUG: Loading: libamplayer.so
00:55:28.575 T:3527873520 ERROR: Unable to load libamplayer.so, reason: libamplayer.so: cannot open shared object file: No such file or directory
00:55:28.575 T:3527873520 DEBUG: Dll libamplayer.so was not found in path
00:55:28.575 T:3527873520 WARNING: CAMLCodec::CAMLCodec libamplayer.so not found, trying libamcodec.so instead
00:55:28.575 T:3527873520 DEBUG: SECTION:LoadDLL(libamcodec.so)
00:55:28.577 T:3527873520 DEBUG: Loading: libamcodec.so
00:55:28.579 T:3527873520 INFO: DVDVideoCodecAmlogic: Opened Amlogic Codec
00:55:28.579 T:3527873520 DEBUG: FactoryCodec - Video: am-h264 - Opened
00:55:28.579 T:3527873520 DEBUG: CVideoPlayerVideo::OpenStream - open stream with codec id: 28
00:55:28.580 T:3527873520 NOTICE: Creating video thread
00:55:28.580 T:3328205808 DEBUG: Thread VideoPlayerVideo start, auto delete: false
00:55:28.580 T:3527873520 NOTICE: Opening stream: 1 source: 256
00:55:28.580 T:3328205808 NOTICE: running thread: video_thread
00:55:28.580 T:3527873520 NOTICE: Finding audio codec for: 86028
00:55:28.580 T:3328205808 DEBUG: CAMLCodec::SetSpeed, speed(1000)
00:55:28.580 T:3527873520 DEBUG: FactoryCodec - Audio: passthrough - Opening
00:55:28.580 T:3527873520 DEBUG: FactoryCodec - Audio: passthrough - Failed
00:55:28.580 T:3527873520 DEBUG: FactoryCodec - Audio: FFmpeg - Opening
00:55:28.580 T:3527873520 DEBUG: FactoryCodec - Audio: FFmpeg - Opened
00:55:28.580 T:3527873520 NOTICE: Creating audio thread
00:55:28.580 T:3485930480 DEBUG: Thread VideoPlayerAudio start, auto delete: false
00:55:28.580 T:3527873520 NOTICE: Opening stream: 2 source: 256
00:55:28.580 T:3485930480 NOTICE: running thread: CVideoPlayerAudio::Process()
00:55:28.580 T:3527873520 DEBUG: FactoryCodec - Overlay: Text Subtitle Decoder - Opening
00:55:28.581 T:3527873520 DEBUG: FactoryCodec - Overlay: Text Subtitle Decoder - Opened
00:55:28.581 T:3527873520 DEBUG: ReadEditDecisionLists - Checking for edit decision lists (EDL) on local drive or remote share for: nfs://10.0.0.1/The.Invisible.Guest.mkv
00:55:28.582 T:3527873520 DEBUG: Process - Start position set to last stopped position: 817927
00:55:28.620 T:3527873520 DEBUG: SeekTime - seek ended up on time 818192
00:55:28.620 T:3527873520 DEBUG: Process - starting demuxer from: 817927
00:55:28.620 T:3527873520 DEBUG: OnPlayBackStarted: play state was 1, starting 1
00:55:28.621 T:4110807040 DEBUG: PlayFile: OpenFile succeed, play state 2
00:55:28.621 T:4110807040 DEBUG: OnPlayBackStarted: play state was 2, starting 0
00:55:28.621 T:3328205808 DEBUG: CVideoPlayerVideo - video decoder returned error
00:55:28.626 T:3527873520 DEBUG: CVideoPlayer::SetCaching - caching state 2
00:55:28.626 T:3328205808 DEBUG: CAMLCodec::SetSpeed, speed(0)
00:55:28.627 T:3527873520 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
00:55:28.631 T:3485930480 DEBUG: CDVDAudio::Pause - pausing audio stream
00:55:28.633 T:4110799856 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
00:55:28.633 T:4110799856 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
00:55:28.634 T:4110799856 DEBUG: UPnP: Building didl for object 'nfs://10.0.0.1/The.Invisible.Guest.mkv'
00:55:28.636 T:3469153264 DEBUG: CGUIInfoManager::SetCurrentMovie(nfs://10.0.0.1/The.Invisible.Guest.mkv)
00:55:28.649 T:3469153264 DEBUG: GetMovieId (nfs://10.0.0.1/The.Invisible.Guest.mkv), query = select idMovie from movie where idFile=355
00:55:28.668 T:3328205808 DEBUG: CVideoPlayerVideo - video decoder returned error
00:55:28.669 T:3328205808 INFO: CVideoPlayerVideo - Stillframe left, switching to normal playback
00:55:28.670 T:3328205808 DEBUG: codecid_to_vformat, id(28) -> vformat(2)
00:55:28.670 T:3328205808 DEBUG: codec_tag_to_vdec_type, codec_tag(28) -> vdec_type(4)
00:55:28.670 T:3328205808 DEBUG: CAMLCodec::OpenDecoder hints.width(1920), hints.height(808), hints.codec(28), hints.codec_tag(0)
00:55:28.670 T:3328205808 DEBUG: CAMLCodec::OpenDecoder hints.fpsrate(24000), hints.fpsscale(1001), video_rate(4004)
00:55:28.670 T:3328205808 DEBUG: CAMLCodec::OpenDecoder hints.aspect(2.376238), video_ratio.num(1), video_ratio.den(1)
00:55:28.670 T:3328205808 DEBUG: CAMLCodec::OpenDecoder hints.orientation(0), hints.forced_aspect(1), hints.extrasize(39)
00:55:28.709 T:3485930480 NOTICE: Creating audio stream (codec id: 86028, channels: 6, sample rate: 48000, no pass-through)
00:55:28.709 T:3485930480 DEBUG: CVideoPlayerAudio:: synctype set to 0: clock feedback
00:55:28.711 T:4070568944 INFO: CActiveAESink::OpenSink - initialize sink
00:55:28.711 T:4070568944 DEBUG: CActiveAESink::OpenSink - trying to open device ALSA:hdmi:CARD=AMLM8AUDIO,DEV=0
00:55:28.711 T:4070568944 INFO: CAESinkALSA::Initialize - Attempting to open device "@:CARD=AMLM8AUDIO,DEV=0"
00:55:28.714 T:3328205808 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 64Bit
00:55:28.718 T:4070568944 INFO: CAESinkALSA::Initialize - Opened device "surround51:CARD=AMLM8AUDIO,DEV=0"
00:55:28.725 T:4070568944 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
00:55:28.725 T:4070568944 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
00:55:28.725 T:4070568944 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 9600
00:55:28.747 T:4070568944 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 128, bufferSize 9600
00:55:28.747 T:4070568944 DEBUG: Audio Driver reports too low periodSize 128 - will use 2 fragments
00:55:28.747 T:4070568944 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 200 ms
00:55:28.747 T:4070568944 DEBUG: CAESinkALSA::GetChannelLayout - Input Channel Count: 6 Output Channel Count: 8
00:55:28.747 T:4070568944 DEBUG: CAESinkALSA::GetChannelLayout - Requested Layout: FL,FR,FC,LFE,SL,SR
00:55:28.747 T:4070568944 DEBUG: CAESinkALSA::GetChannelLayout - Got Layout: FL,FR,SL,SR,FC,LFE,BL,BR (ALSA: none)
00:55:28.748 T:4070568944 DEBUG: CActiveAESink::OpenSink - ALSA Initialized:
00:55:28.748 T:4070568944 DEBUG: Output Device : AML-M8AUDIO
00:55:28.748 T:4070568944 DEBUG: Sample Rate : 48000
00:55:28.748 T:4070568944 DEBUG: Sample Format : AE_FMT_S32NE
00:55:28.748 T:4070568944 DEBUG: Channel Count : 8
00:55:28.748 T:4070568944 DEBUG: Channel Layout: FL,FR,SL,SR,FC,LFE,BL,BR
00:55:28.748 T:4070568944 DEBUG: Frames : 256
00:55:28.748 T:4070568944 DEBUG: Frame Size : 32
00:55:28.755 T:4081054704 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted
00:55:28.766 T:3527873520 DEBUG: Previous line repeats 1 times.
00:55:28.767 T:3527873520 DEBUG: CVideoPlayer::HandleMessages - player started 1
00:55:28.854 T:3328205808 DEBUG: DVDVideoCodecAmlogic: detected new framerate(23.976024), video_rate(4004)
00:55:29.103 T:3328205808 DEBUG: CRenderManager::Configure - change configuration. 1920x808. display: 1920x808. framerate: 23.98. format: AMLCODEC
00:55:29.116 T:4110807040 DEBUG: DeleteRenderer - deleting renderer
00:55:29.116 T:4110807040 DEBUG: LinuxRendererGL: Cleaning up GL resources
00:55:29.116 T:4110807040 DEBUG: CRenderManager::Configure - 4
00:55:29.117 T:4110807040 DEBUG: CAMLCodec::SetVideo3dMode:mode3d(0x0)
00:55:29.117 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:display(0,0,1920,1080)
00:55:29.117 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:gui(0,0,1920,1080)
00:55:29.117 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:m_dst_rect(0,136,1919,808)
00:55:29.117 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:dst_rect(0,136,1919,808)
00:55:29.117 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:m_stereo_mode(0)
00:55:29.117 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:m_stereo_view(0)
00:55:29.117 T:4110807040 DEBUG: Activating window ID: 12005
00:55:29.117 T:4110807040 DEBUG: ------ Window Deinit (Home.xml) ------
00:55:29.118 T:4110807040 DEBUG: ------ Window Init (VideoFullScreen.xml) ------
00:55:29.119 T:3527873520 DEBUG: CVideoPlayer::HandleMessages - player started 2
00:55:29.119 T:3527873520 DEBUG: CVideoPlayer::SetCaching - caching state 3
00:55:29.119 T:3527873520 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000
00:55:29.119 T:3527873520 DEBUG: CVideoPlayer::SetCaching - caching state 0
00:55:29.119 T:3527873520 DEBUG: VideoPlayer::Sync - Audio - pts: 818431000.000000, cache: 349388.637159, totalcache: 600000.023842
00:55:29.119 T:3527873520 DEBUG: VideoPlayer::Sync - Video - pts: 818192000.000000, cache: 50000.000000, totalcache: 100000.000000
00:55:29.120 T:3485930480 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_RESYNC(818081611.362841)
00:55:29.120 T:3485930480 DEBUG: CDVDAudio::Resume - resume audio stream
00:55:29.120 T:4081054704 DEBUG: ActiveAE - start sync of audio stream
00:55:29.142 T:3328205808 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(818081611.362841)
00:55:29.216 T:4110807040 DEBUG: CAMLCodec::SetVideo3dMode:mode3d(0x0)
00:55:29.216 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:display(0,0,1920,1080)
00:55:29.216 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:gui(0,0,1920,1080)
00:55:29.216 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:m_dst_rect(0,136,1920,808)
00:55:29.216 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:dst_rect(0,136,1920,808)
00:55:29.217 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:m_stereo_mode(0)
00:55:29.217 T:4110807040 DEBUG: CAMLCodec::SetVideoRect:m_stereo_view(0)
00:55:29.223 T:4081054704 DEBUG: ActiveAE::SyncStream - average error of -23.984433, start adjusting
00:55:29.223 T:4081054704 DEBUG: ActiveAE::SyncStream - average error -18.984433 below threshold of 30.000000
cat /sys/class/amhdmitx/amhdmitx0/aud_cap gives me the following output:
PCM, 2 ch, 32/44.1/48 kHz, 16/20/24 bit
AC-3, 6 ch, 32/44.1/48 kHz, bit```
Thanks for your effort so far!
