Hi, New to the forum, go easy on me!
Ive just got a Pi2, ran the installer, fired up and all seems to be OK.
When the Pi boots up though, I get 4 errors:
Missing device node for CPU 0
Missing device node for CPU 1
Missing device node for CPU 2
Missing device node for CPU 3
is this anything to worry about, or is there a fix to prevent this?
im having the node error on all cpu 0 1 2 3 too i had this working before befor installing rasbian etc formatted sd card a million times reistalled osmc several times get this error cud it be the firmware after updating the pi in raspbian or is it all reset on reinstallation of osmc fyi it wont work with openelec for rpi2 neither im at a loss here please h
These errors are unlikely to be causing your problem. Describing what happened prior to the failure to boot would be more helpful. Giving as many details as possible (network type, connected devices, install media, etc) in a separate thread with an accurate and concise title would be more helpful.
So I downloaded the OSMC alpha image, placed the alpha 4 image on a 64gb Micro SD Card using Win32DiskImager and plug this card in my newly unbox Pi 2 with a USB Keyboard connected, a 100mb network cable (known working), a hdmi to HDMI connected monitor cable with a 2a 5.3v Micro USB power adapter. I get the Rainbow graphic followed by these 4 errors - this then cycles continuously. That explains exactly my situation.
Got my Pi 2 in the mail today, installed raspberry and immediatly looked for an alternative. within the hour i had installed the alpha4 OSMC build and had it playing any video’s i had to throw at it.
So much better than the HTPC build i bad planned until the pi 2 release notes caught my eye.
Donated to the cause because this is WAY BETTER than any other HTPC I could dream up on a $100 budget.
I too get the cpu core errors on boot, but OSMC boots shortly after and runs great. no issues with HD content
I get the same error on a 4 GB Kingston MicroSD as well. It is a brand new Pi 2 and I am having trouble getting any Pi 2 compatible image to boot (noobs)- not sure if its defective or just a new firmware yet to be seen - The noobs image mounts fine on my Pi B+
