The 3.5mm ports on the side of the vero… Which is for IR and which is for audio? They are not labelled and there is no information about them in the manual
Based on this post the one nearest to the HDMI port is for audio
OK. I’ll try that. I suggest an addendum or correction for the manual. Maybe a diagram showing the ports and what they are for, or in the next printing of the manuals, add the missing information.
See also this. You will know if you have the wrong cable - it will blow your speakers out with hum. ![]()
