Maybe related: the crash happens at random periods when the Vero is not being used. i’m not sure if the problems are related. As I said, the disappearing menus happen both after a crash or on shutdown.
Could you please post a screenshot of the issue?
Logs would also be helpful:
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
It can’t be a skinshortcuts issue as it only controls the way the home menu is built. @tony-r’s screenshots clearly show that also other parts of the skin are affected. It looks very much like the profiles bug we addressed a while back…
Are you using Kodi profiles and is this happening with a different profile than ‘master’, @tony-r? If not, I’m pretty much out of ideas as I’ve never seen this before unrelated to profiles.
Please have a look at this thread: Item Text Missing after November Update It looks like the same issue and suggests that it’s some settings corruption issue. The solution advised there did help the user to solve the problem
@chillbo I tried moving directories as in the suggested post. Moving the.kody directory gave me a clean desktop but all my settings and additions were missing. Not unexpected. I reverted to the old one.
I have a lot of additions so will live with the problem. Now I know which missing menu item to click to restore, it takes about 30 seconds to fix.
My recently added TV videos icons are now missing, which is annoying, but I’m not prepared to blow my setup away and spend hours rebuilding it.
