until last year (before the new OSMC came out), whenever I located a resource located on a SMB share (Music, Video etc.) OSMC automatically tried to wake up my NAS - with success.
Now OSMC doesn’t even try it anymore.
Is that a known (and still missing) issue?
Second thing (minor): In several dialogues, e.g. search or result screens, bold headlines show a kind of tag at the end, like /B.
Rather a cosmetical bug, but maybe it can be fixed with the next releases…?
You need to enable debug logging as described in the log provided. Then try and browse to an SMB share, reboot. Upload logs via my MyOSMC, then provide the link. You can then disable debug logging.
Hi Tom,
honestly, IMO the latest OSMC locked down the Linux on my Pi a lot.
E.g. SSH was disabled, which was enabled before I upgraded.
Now I finally found out how to re-enable it, and am now connected via Total Commander again finally.
Since there is no “Enable debug logging” shown in “My OSMC”, please tell me where to browse to in the Linux structure (I guess there is a XML file or something to enable it).
Not sure whats going on with system is enabled by default, I think it can be disabled during the wizard on first boot. Have you installed OSMC via the installer on the website or is this a noobs or multi-distro setup?
I think there is a misunderstanding, so I try to explain the issue once more:
The problem is not that the NAS is not reachable, that’s expected.
But in the past, means at OSMC versions until last year, when you would access such an offline SMB resource, OSMC would automatically send a Wake on LAN command to the NAS, which is not the case anymore now.
Indeed a super hot trance - I found why it still doesn’t work for me:
This option was already switched on, however it tries to wake up my NAS using an old IP address of the Pi (192.168.10.16), which is not valid anymore.
Since I disabled WLAN at the Pi recently and since then only use the physical LAN adapter, I somehow need to tell OSMC the new IP address (192.168.10.18) for using Wake on LAN.
Any ideas how to achieve that?
You mean e.g. at Videos => Files? Yes, works like a charm, but I used the NetBIOS name and not the IP, so I am actually more dynamic here in case of an IP change
Only WOL doesn’t work anymore…
