As I mentioned on my first post. I have a Raspberry Pi3 running OSMC on this same monitor that does recognizes the correct native resolution of my Dell monitor. 1900x1200.
hope that helps. I believe if the rpi3 settings were merged to the Vero 4k it will work. All my PIs (running OSMC or others distros) always recognized my native monitor resolution properly.
Your monitor appears to be advertising 1080p60Hz as it’s preferred and supported mode, which is why this is being chosen.
Currently, Vero 4K doesn’t support the 1920x1200p mode as this is not often found. I can add support for it but I cannot remember off the top of my head if additional work is needed to make it work with Kodi.
It is not a TV. It is a Dell UltraSharp 2408WFP monitor.
Please, do. I intend to use Vero 4k on this monitor. I needed a HEVC capable device on it.
Like I said before I have been running OSMC (On this monitor) since it was called Raspbmc (Rpi B+ in 2014), Rp2 and Rp3 and all version recognized my monitor properly.
I had a look at this today. Support for VESA modes was included previously:
The problem here is that they are only 60Hz modes. This wouldn’t be very smooth for video playback and you wouldn’t be able to take advantage of the ‘Adjust Refresh Rate’ option. This would give you motion judder, particularly on panning shots.
It doesn’t look like your display supports anything other than 50Hz or 60Hz, which doesn’t make it very ideal for watching video.
I will look at reincluding these modes; but will check with the SoC manufacturer first. They were likely removed because they are not appropriate for video playback.
FWIW and as I said in the other thread. I have been running OSMC on a Pi1B+ for years with 1360x768x50 and never had any issues with video quality. We never watch HD though.
It’s not the quality that’s going to be the issue, it’s the refresh rate. It will be the same experience as other OSMC devices. If you haven’t noticed a problem on those, then you won’t here either.
I will add support for these modes in the next update.
