"Mounting point" duplicated for external HD
Hi there,
recently i’ve got a problem that made all my library not work. As far i could understand, the problem that happened was: my external hd was “mounted” in another directory.
normaly the osmc automount the external hd on: /media/external_hd but in this case, it had 2 directories: /media/external_hd and /media/external_hd_ where the hd was actualy monted on the second one, with the sulfix “_”, so this was creating my problem of messing with the library that was pointing to the directory without the sulfix.
My question is, how can i remove the “original” directory, leaving it available for the hd be monted there?
I already removed the directory (rmdir) and did a reboot, but after the reboot the directory was there again…
I’ve already have rebooted the vero without the hd and again, it mounts the hd on the /media/external_hd_ directory…
Unplug the hard drive and reboot and then show us what the contents of /media look like, this should be empty (or at least not reference this hard drive)
As i said previously, the media directory has the folder of my external_hd wich is: /media/SAMSUNG and here i can se some structures of my HD
I already remove these structures, the directory /media/SAMSUNG and rebooted with the HD and without the HD, but every time that i reboot, the directory /media/SAMSUNG is created again
If i plug the HD it will create a new directory: /media/SAMSUNG_
What i wanted to see was whether both of these can be cleared out and then what it does after reboot.
I think we would like to take a look at the smb.conf file which should be located in /etc but it might be in /etc/smb or something similar (sorry, i’m away from an OSMC device so i can’t check there these live.
This is the content of smb.conf:
[global]
# If you require a fully custom smb.conf create smb-local.conf instead of editing smb.conf so your
# configuration will not be overwritten by samba upgrades. You can use smb.conf as a template by
# copying it to smb-local.conf then removing the config file line below in the new file. If you only
# need to add some additional shares see smb-shares.conf below for a simpler way to do this.
    config file = /etc/samba/smb-local.conf
    workgroup = WORKGROUP
    security=user
    follow symlinks = yes
    wide links = no
    unix extensions = no
    lock directory = /var/cache/samba
    load printers = no
    printing = bsd
    printcap name = /dev/null
    disable spoolss = yes
    log level = 1
    map to guest = bad user
    fruit:model = Macmini
#   usershare template share = automount template
# Automount template disabled to work around a samba bug causing crashes accessing external drives.
    read raw = Yes
    write raw = Yes
    strict locking = no
    min receivefile size = 16384
    use sendfile = true
    aio read size = 2048
    aio write size = 2048
    socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=131072 SO_SNDBUF=131072
[osmc]
    browsable = yes
    read only = no
    valid users = osmc
    path = /home/osmc
    comment = OSMC Home Directory
[automount template]
    browseable = yes
    -valid = no
    valid users = osmc
    path = %P
    hide files = /$RECYCLE.BIN/System Volume Information/desktop.ini/thumbs.db/
# Add custom shares in smb-shares.conf instead of editing smb.conf so they will not be
# overwritten by samba updates. You can only add new shares to smb-shares.conf, not change
# the default shares or global options. If you need full control see smb-local.conf above.
include = /etc/samba/smb-shares.conf
and the content of /etc/samba/smb-shares.conf:
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Some options that are often worth tuning have been included as
# commented-out examples in this file.
#  - When such options are commented with ";", the proposed setting
#    differs from the default Samba behaviour
#  - When commented with "#", the proposed setting is the default
#    behaviour of Samba but the option is considered important
#    enough to be mentioned here
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
#======================= Global Settings =======================
[global]
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
;   interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself.  However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
;   bind interfaces only = yes
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
   log file = /var/log/samba/log.%m
# Cap the size of the individual log files (in KiB).
   max log size = 1000
# We want Samba to only log to /var/log/samba/log.{smbd,nmbd}.
# Append syslog@1 if you want important messages to be sent to syslog too.
   logging = file
# Do something sensible when Samba crashes: mail the admin a backtrace
   panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# Server role. Defines in which mode Samba will operate. Possible
# values are "standalone server", "member server", "classic primary
# domain controller", "classic backup domain controller", "active
# directory domain controller".
# Most people will want "standalone server" or "member server".
# Running as "active directory domain controller" will require first
# running "samba-tool domain provision" to wipe databases and create a
# new domain.
   server role = standalone server
   obey pam restrictions = yes
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
   unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
   passwd program = /usr/bin/passwd %u
   passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
   pam password change = yes
# This option controls how unsuccessful authentication attempts are mapped
# to anonymous connections
########## Domains ###########
# The following settings only takes effect if 'server role = classic
# primary domain controller', 'server role = classic backup domain controller'
# or 'domain logons' is set
# It specifies the location of the user's
# profile directory from the client point of view) The following
# required a [profiles] share to be setup on the samba server (see
# below)
;   logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
# (this is Samba's default)
#   logon path = \\%N\%U\profile
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of a user's home directory (from the client
# point of view)
;   logon drive = H:
#   logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
;   logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe.  The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
# This allows machine accounts to be created on the domain controller via the
# SAMR RPC pipe.
# The following assumes a "machines" group exists on the system
; add machine script  = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
# This allows Unix groups to be created on the domain controller via the SAMR
# RPC pipe.
; add group script = /usr/sbin/addgroup --force-badname %g
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
;   include = /home/samba/etc/smb.conf.%m
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
;   idmap config * :              backend = tdb
;   idmap config * :              range   = 3000-7999
;   idmap config YOURDOMAINHERE : backend = tdb
;   idmap config YOURDOMAINHERE : range   = 100000-999999
;   template shell = /bin/bash
# Setup usershare options to enable non-root users to share folders
# with the net usershare command.
# Maximum number of usershare. 0 means that usershare is disabled.
#   usershare max shares = 100
# Allow users who've been granted usershare privileges to create
# public shares, not just authenticated ones
   usershare allow guests = yes
#======================= Share Definitions =======================
[homes]
   comment = Home Directories
   browseable = no
# By default, the home directories are exported read-only. Change the
# next parameter to 'no' if you want to be able to write to them.
   read only = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
   create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
   directory mask = 0700
# By default, \\server\username shares can be connected to by anyone
# with access to the samba server.
# The following parameter makes sure that only "username" can connect
# to \\server\username
# This might need tweaking when using external authentication schemes
   valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
;   comment = Network Logon Service
;   path = /home/samba/netlogon
;   guest ok = yes
;   read only = yes
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
;   comment = Users profiles
;   path = /home/samba/profiles
;   guest ok = no
;   browseable = no
;   create mask = 0600
;   directory mask = 0700
[printers]
   comment = All Printers
   browseable = no
   path = /var/spool/samba
   printable = yes
   guest ok = no
   read only = yes
   create mask = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   guest ok = no
# Uncomment to allow remote administration of Windows print drivers.
# You may need to replace 'lpadmin' with the name of the group your
# admin users are members of.
# Please note that you also need to set appropriate Unix permissions
# to the drivers directory for these users to have write rights in it
;   write list = root, @lpadmin
Here i can’t see anything related to the folders that i mentioned…
Me neither.
So if you reboot without the hard drive attached the phantom folder is still there, then if you clear this out and reboot again (still with the hard drive disconnected) it still comes back?
Correct!
And all this is preventing to use the osmc library…
i know that i could change the library to point to the _ folder, but i don’t know until when it will work that way
Try submitting logs and we can see if we can see anything in there
your smb.conf has this line:
what is in that file?
The file doesn’t exists
Did you install the Samba server via the App Store?
Hi Sam!
Yes i did
Thanks for clarifying.
Can you upload some logs so we can see if you’ve mounted the drive in another way (i.e. fstab)?
Here go
https://paste.kodi.tv/elizuquviz.kodi
After a few tests, i’ve unistalled the samba, rebooted, and the folder was created again, the external drive was disconnected during the all process
You might be getting to the point where a clean install may be a good idea.
hahahahaha, i have the vero 4k since 2020, i’ve just did a clean install in about 20 days… this should not be the solution, this isn’t windows.
When you say the mountpoint is duplicated?
Do you mean the share shows up twice on other PCs?
Or do you mean the /media directory has multiple entries…
The media has 2 directories: /media/external_hd and /media/external_hd_
Where the /media/external_hd has nothing and the content of external hd is on /media/external_hd_ directory
This one might be for @dbmandrake
