Recently I moved to using a NAS as storage for my media files, the nas is hardwired via 10gbe connection and my Raspberry Pi 4 is using wifi and NFS to connect.
I cleared out my DB’s and textures and removed existing sources. I then added my media from the nas and they all scanned in ok, but album art isn’t showing at all at the moment, and almost seems like it is partially loading.
All movies/tv shows have metadata and images in the folder.
I also added them to Kodi on a pc via SMB and loads perfectly fine.
Any suggestions? I also have tested on a fresh install and same result.
