I tried it several times, and i had some other issues with the osmc update itself (Update Installation Error - #13 by Regnalf) that’s been solved so far. I hopped it will also solve this problem, but it didn’t. Any other suggestions?
I also reboot it many times, that would be to easy!!
I’ve struggled with the option to reset it over the osmc menu, but now i did it! After reset and reboot it seems to be up to date now. All addons updated and the movie scraper works so far.
So, i never will know what the problem was …
I hope this will be the last reset for long time :-/
Is this supposed to be working with osmc skin and media from usb ? I wanted to go and install it but was surprised its already installed and enabled by default ? But it does nothing
I went to settings → addon browser and searched for themoviedb.org to try and install the scraper and check it out for myself I was surprised to see that its already installed and enabled on my vero 4k + by default because I haven’t installed it myself.
My question is if this addon is supposed to work with default osmc skin and for media on usb stick because if its installed it should be doing something but I didn’t even know I have it untill half an hour ago.
