Movies issues after January update (Vero4K)
If you wait, then the SSH connection is restored after.
Thanks. The important thing is that my videos are watchable.
However if you have a fix for:
  • my remote control that crashes from time to time
  • my Vero which also restarts by itself from time to time when it is on standby
  • and which turns on my TV at night (which also turns on my sound bar) while I sleep (and I assure you that no one in my household is a sleepwalker)
    so I take them…
I would try a fresh install.
That’s what you said last time. So I did it last summer. And the same bugs occurs.
Are you still using the Aeon Nox skin?
That’s great news. Will the fix be made available via the stable repository this week?
Hi finally tried the fix , issue resolved
Thanks sam and everyone contributed to fix it
No. Amber.
I would suggest some new logs so we can check again.
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/ugenonoqal
@sam_nazarko would it be possible to move this fix into the stable repository?
Yes – when we release the next stable update
Did you see?
I saw your logs but don’t understand some of the issues you have reported.
Could you clarify what you mean by this?
I’d suggest a new post with a fresh installation and debug logs showing any problems you are experiencing.
