No. The update has that conf file by default.
The Stretch update should be released within the next 24 hours.
BWAHAHAHA, kewl. Was familiar with the whole pulseaudio driver issues, etc. so the first thing I thought of was a new audio driver.
The update has now been released.
If one had been on the Stretch test build until now, will the update also show up?
Just manually let my Vero check for updates: nothing. Or did the update install without me noticing (version is 2017.12-1)?
2017.12-1 is the newly released version. It sounds like you are still on stretch-devel. As advised in the Stretch testing thread, you probably want to switch back to stretch, unless you want to stay on the bleeding edge.
Oh, I obviously missed something there⦠
This is what my sources.list looks like:
deb http://ftp.debian.org/debian stretch main contrib non-free
deb http://ftp.debian.org/debian/ stretch-updates main contrib non-free
deb http://security.debian.org/ stretch/updates main contrib non-free
deb http://apt.osmc.tv stretch main
Isnāt that correct?
Yes, so it sounds like you updated your device after we pushed it to release.
From what you had described, I thought you had updated to 2017.12-1 some time ago, but it seems this isnāt the case.
2017.12-1 is the latest version, so you are up to date.
Ok, sweet! Canāt remember any update happening though. Strange
But doesnāt matter, if all is correct.
Your device must have updated for you to get the 2017.12-1 update.
Logs can show timestamps if you have issues.
Seems it mustāve done it automatically on its own, yep⦠I didnāt press any OK button for it
There donāt seem to be issues. Wouldnāt even have noticed, if I didnāt try checking for an update manually without success.
OSMC will never update itself without your consent.
This has been discussed before. See Update killed me - #3 by sam_nazarko.
If you donāt acknowledge the update, it will not install itself. If you are concerned, the logs will tell the whole story.
Well, then my memory is starting to fail me
Too young for it to start happening
Itās happening to me too. Perhaps itās the weather.
Now I remember⦠There was an update a few days ago. And I had changed stretch-devel to stretch already some time ago.
Well, doesnāt help too much to dig, if the memory just stays frozen and grey - like the weather. It surely seems to be that. Or too much reading in the forum. Confusing other peopleās issues with own ones
Initial release of 2017.12-1 was on 31st Dec.
If you were on devel, you would have got it straight away.
So, my brain seems to be working again. Thanks! ![]()
5.1 is still being output as 7.1 pcm. This is as expected or was it supposed to be fixed in this release? Thanks.
This is expected and not a ābugā in the way of all the other issues that were discussed here⦠The audio sink can either open 2 or 8 channels for audio and therefore all audio that has more than 2 channels will be output with 8 channels opened (and filled up with blank channels, if needed).
@sam_nazarko suggested that it might be looked into sometime, but itās not a high priority, I believe, and also depends on the vendor, AMLogic, to do some of the work.
Thanks for clearing that up.
