Hello,
I read the thread Vero 4K+ Review: Finally, a Native Kodi 4K + 3D Do-it-All Player? and ordered der Vero4K+.
Installed kernel 4.9.113-20-osmc though it was not mentioned in this article.
I have now 2 critical issues:
1. MVC MKV files are recognized but not displayed in 3D
- tried differend Resolution and Hz configurations; never changed anything
- starting a mvc video (mkv) it ask for the method to be displayed -> as movie, then it starts playing in 2D and if I open the 3D menu the sliders (3d&2d) are off - cant set 3d to on, but 2d … what ever it is not running in 3D
My HW: Yamaha 680 Receiver with passthrough Video on an LG 55UF860 (passive 3D)
(Was and still is working fine with the Windows MVC build on my Intel NUC)
osmc@xbmc:/sys/class/amhdmitx/amhdmitx0$ more config
cur_VIC: 16
cur_video_param->VIC=16
colordepth: 8bit
colorspace: 422
AVIF VIC: 16
VIC: 16 1920x1080p60hz
Colour depth: 12-bit
Colourspace: YUV422
Colour range: full
EOTF: SDR
YCC colour range: full
PLL clock: 0xc000027b, Vid clock div 0x000a739c
Aspect ratio: 16:9/full frame
audio config: on
audio on/off: on
audio source: I2S
audio type: L-PCM
audio channel num: 2 channels
audio sample rate: 44.1kHz
audio sample size: MAX
3D config: off
/sys/class/amhdmitx/amhdmitx0/disp_cap_3d is empty
2. IR remote not working with One4All RC URC7960
Figured that the far out Jack was for IR …
Setup my One4All for MCE/XBOX RC (Code 0009/1972)
Selected the both config in MyOSMC … not working
Used irrecord (why not integrade this into the OSMC GUI?) what recognizes signals but when it starts to assign Buttons/Keys I get:
“That’s weird because the signal length must be odd!”
Nothing is working … well could try a shorter distance
Please advice for further proceeding.
Thank you
If you need a log please discribe precisely what output you need and where to find it.
