My RF remote has stopped working after a fresh install debian-stretch Kodi v17.6 clean installation on rpi2
In that case, you don’t need to add the rules again.
Removing them may, ironically actually fix the functionality.
I already tried. and I deleted the file “999-not-a-joystick.rules” but the problem persists I will try again one more time.
I deleted the file “999-not-a-joystick.rules” and I created the file “51-these-are-not-joysticks-rm.rules”, the problem is not solved. I deleted both files together still no solution
Ok, I solved it the problem It’s the service eventlircd. So I disabled it via systemctl thanx to @Harvey704 [SOLVED] My RF remote has stopped working after migration to Kodi v17 - #60 by Harvey704
via ssh
sudo systemctl disable eventlircd
and reboot your osmc system.
