My c120 Air mouse has stopped working when a fresh install OSMC images based on Debian Stretch “Kodi v17.6”. the issue is that the all keybord key and the up /down /home/R-Mouse/Back button no longer work, except the gyroscope move of mouse cursor are getting valid signals.
this my log after first boot for a fresh install https://paste.osmc.tv/yovuqavawu
Appreciate any help!
Any suggestions? any help plz
07:28:38.766 T:1925827072 WARNING: CLinuxInputDevice::RelEvent: Unknown rel event code: 10
07:28:38.766 T:1925827072 WARNING: CLinuxInputDevice::RelEvent: Unknown rel event code: 11
07:28:38.766 T:1925827072 WARNING: CLinuxInputDevice::RelEvent: Unknown rel event code: 12
07:28:38.766 T:1925827072 WARNING: CLinuxInputDevice::RelEvent: Unknown rel event code: 13
Check this thread seems to be similar error message in there
I tried but it did not work
So you have the blacklist configured. Have you checked journalctl if they are applied?
I don’t understand you can explain sorry
Did you read through the thread I linked (which also was started by you). In there the solution seemed a blacklist that avoids it being recognised as joystick
I tried this method GitHub - denilsonsa/udev-joystick-blacklist: Fix for keyboard/mouse/tablet being detected as joystick in Linux but nothing
here is what I did
I unplug the USB dongle for my RF remote & Plug it in and run
dmesg | paste-log
New USB device found, idVendor=1d57, idProduct=ad03
I created new udev rule /etc/udev/rules.d/51-not-a-joystick.rules
sudo curl -o /etc/udev/rules.d/51-these-are-not-joysticks.rules
http://paste.osmc.io/raw/agimemukal
> # /etc/udev/rules.d/51-these-are-not-joysticks-rm.rules
> # https://github.com/denilsonsa/udev-joystick-blacklist
> # /etc/udev/rules.d/51-these-are-not-joysticks.rules
> # Using information from https://github.com/denilsonsa/udev-joystick-blacklist
> SUBSYSTEM=="input", ATTRS{idVendor}=="1d57", ATTRS{idProduct}=="ad03", ENV{ID_INPUT_JOYSTICK}=="?*", ENV{ID_INPUT_JOYSTICK}=""
> SUBSYSTEM=="input", ATTRS{idVendor}=="1d57", ATTRS{idProduct}=="ad03", KERNEL=="js[0-9]*", MODE="0000", ENV{ID_INPUT_JOYSTICK}=""
but still having the same problem . its only working as a mouse.
I have the same problem with the Kodi 18 LEIA Build version 17.8-158, 10 Jan 2018 and with LibreELEC (Krypton) 8.2.2 MR.
I dnot know if the problem is due to Debian stretch or Kodi version
We already include the ‘not joystick’ rules in OSMC by default, and I updated them recently.
Can you try reinstall OSMC and check if your adapter is blacklisted already in OSMC?
I will try this night and I will let you know.
i did a clean install 2017.12-1 release “OSMC_TGT_rbp2_2018010”
I still have the same issue
Please see previous suggestion
please explain to me how do I check if my adapter is blacklisted.
grep for the hardware id in udev directory or search there in the not a joystick file that is already present.
my hardware id
and I find them in /etc/udev/rules.d/999-not-a-joystick.rules
line 66 and line 67
