I just received my new Vero 4k. Did a full round of updating to current etc. When I try to play any of my movies I get what appears to be no center channel audio.
My setup is a badass receiver (HDMI). I have the system configured for 5.1 and passthrough on the audio. This works perfectly on the Pi3 that this Vero 4k is replacing. My receiver is showing proper audio codec and channels but I literally have no center channel audio outputting. I have tried a dozen different files just to be sure. Only way I can get center channel is to change from 5.1 to 2.0, but of course that eliminates the surround.
I’ve tried all manners of adjusting the settings and I cant get this to work. Please help!!
Never heard of that brand before. Maybe telling us the actual brand and model would be more helpful. And as always:
Its a Pioneer Elite VSX-LX301… but I honestly don’t see how that matters since it appears the channels are not being properly outputted from the Vero. (I have it set to passthrough). I’ve run Pi’s with OSMC for years without issue across a broad range of receivers and this is the first time Ive seen this. Going through the forums, I can see others have had similar issues, but I haven’t been able to find any concrete resolution as of yet. I’m short on information, but it appears that things were fine until the july '17 update when there was an audio driver update.
I will look at your link to submit a support request. I was just hoping it was a known issue with an easy fix I could apply.
Its all movie files I have tried to stream to it. Most everything is AC3 or DTS, and they all have the same issue with no center channel audio. I do have it set to AML-M8AUDIO, HDMI and Best Match. If I change Number of channels from 5.1 to 2.0 with passthrough disabled I get the center channel back, but then I lose surround sound. No matter what I set anything to, if I enable passthrough, (which is what I want), the receiver indicates all 5 channels and proper codec, but I have no center channel audio.
Thus far the only way Ive been able to get any center channel audio is to have passthrough turned off and number of channels set to 2.0. This is obviously not acceptable for my surround sound desires… hehe
Same deal. If I have channels set to 2.0 with passthrough on, including all the sub passthrough options… I get no center channel output.
I tried a number of fixes outlined in some other posts with no luck, so Im wondering if I need to repave the install to fresh if we are going to troubleshoot.
So just to be clear…
channels set to 2.0 and passthrough off = good center, no surround (receiver displays front and center speakers)
channels set to 2.0 and passthrough on = no center, good surround (receiver displays all 5 speakers)
channels set to 5.1 (or 7.1) and passthrough on or off = no center, good surround (receiver displays all 5 speakers)
Ok, I will see what I can do about getting the logs. Screenshots should be easy, but Ive tried every combo of options on those settings. Everything works perfect on the Pi2 & 3 with the settings Ive used for years.
Ok, I did that and re-setup everything… no joy/same issue. Only way I get center channel is setting to 2.0 channels and passthrough off which also eliminates surround etc. Any other config = no center channel.
I will note that this is a raw install, no addons. Just cracked the box open upon arrival today and ran updates.
Its the same cable (4k compliant) I used with the Pi3 that it replaced. I can try another cable though. Based on what I’ve seen in the forums though, this seems to be a real issue that others are experiencing. I will see about getting some logs.
I tried this already with no success. I was really hopeful when I found that in the forums but still no go. I still have no center channel with passthrough enabled and more than 2.0 channels selected
Ok, than it must be a different issue. Suggest you provide debug enabled logs and the screenshots of the audio settings and hopefully tomorrow someone with more audio knowledge can try to help.
Thank you for the assistance, I really appreciate it. I guess I’ll need to figure how best to gather the necessary logs. I wasn’t expecting this after years of non-issues on the Pi, but at this point the Pi’s don’t have the horsepower to keep up. I have several more orders for the Vero 4k that I have to hold on until I sort this audio issue out.
