I just received my new Vero over the weekend and spent a few hours setting it up. I am completely new to OSMC. I used XBMC on a jail-broken Gen 1 Apple TV back in 2008 but that’s the extent of my experience. For example it took me quite a while to figure out how to add my TimeCapsule SMB share to the Videos section but now I’ve got it all working. I think adding a network share certainly isn’t easy or obvious for non-techies or first time users. The other major issue I experienced was related to HDMI connectivity to my 2006 Panasonic Plasma. I kept getting a really fuzzy/mangled UI when initially starting Vero. I thought it was the HDMI cable and tried several others - it worked with the cable that my Apple TV was using! I finally figured out it was an issue with my AV amp set-up but because of all the cable swapping I did find that Vero basically mangled the UI to the point it was impossible to use (extremely large, fuzzy, most options off-screen) when the HDMI cable is unplugged/swapped. Once I got the set-up correct on the AV amp I had to manually adjust the resolution in System Settings and then I got the lovely crisp OSMC UI!
Questions
Is there an option to sleep or suspend Vero when not in use? Initially I was using the shutdown option in the Power settings menu but then I realised that there was no way to power Vero back up without removing and re-inserting the power lead. So now I am just leaving it on all of the time but ideally I’d like to be able to sleep and wake Vero using my Harmony Universal remote.
Speaking of the remote, I use a Logitech Harmony 900 universal remote and have manually added the Vero remote commands since Vero/OSMC isn’t in Harmony’s database. However I wasn’t 100% sure what all of the buttons on Vero remote actually do. Most are obvious of course but a couple aren’t. Is there any documentation / guide on the remote buttons? That way I can add them to Harmony.
How do you completely re-install OSMC on Vero if needed? On the Quick Start Guide page it states:
For those that like to tinker and accidentally stumble in to some trouble, you can re-download the Vero software on to your device at any time at Download - OSMC
However I downloaded the OSMC Installer on my Mac and the host installer app only offers to install to either a Raspberry Pi 1 or 2 - the Vero is not listed. So how do you re-install (if needed) the base OSMC software to Vero?
Is it possible to create a list of unwatched TV shows, like you get on the native Apple TV? I thought it might be possible to use a smart playlist but there doesn’t seem to be an option to create a playlist based on the ‘watched’ status of a given TV episode. Not sure if PlayCounts would work because I haven’t played the other episodes on Vero, I just marked them as watched.
Is it safe to change the OSMC account password on the Vero? For security reasons I would like to change it but I wanted to know if that would cause any issues with future updates or functionality of Vero.
Bugs
When there’s a software update available the alert notification icon appears slightly obscured (off screen) at the top left hand corner of the main OSMC menu screen.
I frequently experience a hang when using the Power \ Reboot option to restart OSMC/Kodi. Sometimes Vero successfully reboots but more often than not it simply freezes with the ‘Power’ dialog still on screen and nothing else happens. Since there’s no on/off switch on Vero I have to pull the power lead in order to restart Vero. Is this a known issue and is there anything I can do to troubleshoot it? I’ve seen one other mention of a similar issue on this forum (with a Raspberry Pi 2 not Vero) and the response was that this was probably related to Add-Ons and NFS mounts. I haven’t installed any Add-ons and I am not using NSF mounts.
When adding a network share, the IP address option on the text entry screen doesn’t seem to work. Whenever I select it Vero just freezes and becomes unresponsive for 2-3 minutes (I can’t move or enter any text or exit the screen and none of the buttons on the remote have any affect). Then suddenly the interface starts working again and I can move the cursor and select a different option. Once the UI becomes responsive again the IP address text entry option still doesn’t work.
Other folks have reported this but I thought I’d mention it again. OSMC seems to create duplicate TV show listings due to the hidden ._ AppleDouble files on SMB shares that contain files that were copied to the share using OS X Finder. Apparently this is a known bug in Kodi and is already patched and should be fixed in next release of OSMC. I am not sure if that bug fix has been included in the latest OSMC release but I am still getting the issue. I have attempted to work-around it by adding an advancedsettings.xml file to my kodi userdata folder. Not sure if this has worked so far.
