Hello folks,
a good friend suggested me a Vero 4k to replace the Roku as I was sick of non-stop the video format support issues.
this said, the magnificent piece showed up last night, I connected it… and now sitting with the “now what?” question.
My set up is as follows:
Windows 10 Home PC (will be upgraded to pro in a bit) dedicated to serving video data from 3 shared folders. Currently, it is running Serviio server because Roku isn’t smart enough to see shared drives on its own.
Vero is connected via 5ghz wifi channel, and is the only device sitting on it; I know it is seeing the wifi - the IP address was obtained, and it sees internet - it pulled weather.
questions:
- How do I get Vero to see my shared drives? I am not familiar with samba; is there a step by step instruction for this?
- Is there a way to configure Vero to have several shortcuts to the shared folders? (It needs to pass the wife test. Say, if you select “Videos”, can the next option be “folder A”, “folder B” and folder C"?)
- Is there a way to remote into vero to make the changes or do I have to make all the changes via UI?
thank you in advance
