I´m so sorry I didn’t know how work speaker-test utility and I had swicht off my amp
the news are that despite of the command output the 6 speaker sound correctly.
This is the amixer output:
osmc@osmc:~$ amixer -c1 contents
numid=18,iface=MIXER,name=‘PCM Capture Source’
; type=ENUMERATED,access=rw------,values=1,items=2
; Item #0 ‘Unit 23’
; Item #1 ‘Unit 23’
amixer: Control hw:1 element read error: Broken pipe
numid=13,iface=MIXER,name=‘PCM Capture Switch’
; type=BOOLEAN,access=rw------,values=1
: values=on
numid=16,iface=MIXER,name=‘PCM Capture Switch’,index=1
: values=on
numid=14,iface=MIXER,name=‘PCM Capture Volume’
; type=INTEGER,access=rw—R–,values=2,min=0,max=28,step=0
: values=16,16
| dBminmax-min=-16.00dB,max=12.00dB
numid=17,iface=MIXER,name=‘PCM Capture Volume’,index=1
: values=16,16
numid=12,iface=MIXER,name=‘IEC958 In Playback Switch’
: values=on
numid=15,iface=MIXER,name=‘Auto Gain Control’
: values=on
numid=11,iface=MIXER,name=‘Input Gain Pad Control’
: values=off
numid=5,iface=MIXER,name=‘Speaker Playback Switch’
: values=on
numid=7,iface=MIXER,name=‘Speaker Playback Switch’,index=1
: values=off
numid=9,iface=MIXER,name=‘Speaker Playback Switch’,index=2
: values=on
numid=6,iface=MIXER,name=‘Speaker Playback Volume’
; type=INTEGER,access=rw—R–,values=2,min=0,max=31,step=0
: values=9,9
| dBminmax-min=-34.50dB,max=12.00dB
numid=8,iface=MIXER,name=‘Speaker Playback Volume’,index=1
: values=23,23
numid=10,iface=MIXER,name=‘Speaker Playback Volume’,index=2
; type=INTEGER,access=rw—R–,values=6,min=0,max=55,step=0
: values=55,55,55,55,55,55
| dBminmax-min=-55.00dB,max=0.00dB
numid=1,iface=PCM,name=‘Playback Channel Map’
; type=INTEGER,access=r----R–,values=2,min=0,max=36,step=0
: values=0,0
| container
| chmap-fixed=FL,FR
| chmap-fixed=FL,FR,RL,RR
| chmap-fixed=FL,FR,FC,LFE,RL,RR
numid=4,iface=PCM,name=‘Capture Channel Map’,device=1
: values=0,0
| container
| chmap-fixed=FL,FR
numid=2,iface=PCM,name=‘Playback Channel Map’,device=1
: values=0,0
| container
| chmap-fixed=FL,FR
numid=3,iface=PCM,name=‘Playback Channel Map’,device=2
: values=0,0
| container
| chmap-fixed=FL,FR
