I just tried play video from my new action camera.
Video is OK, but I have no audio at all. Sound format is AAC single channel (center).
Vero4K is connected directly to TV. Same video plays fine in windows based kodi box.
Could you please help resolve this?
Mediainfo:
General
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/mp41)
File size : 431 MiB
Duration : 1 min 33 s
Overall bit rate : 38.6 Mb/s
Video
Format : AVC
Format profile : Main@L5.1
Format settings, CABAC : Yes
Format settings, RefFrames : 1 frame
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Source duration : 1 min 33 s
Bit rate : 38.5 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.155
Stream size : 430 MiB (100%)
Source stream size : 430 MiB (100%)
Language : English
Color range : Limited
Color primaries : BT.601 PAL
Transfer characteristics : BT.601
Matrix coefficients : BT.601
mdhd_Duration : 93732
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Bit rate mode : Variable
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 8 000 Hz
Frame rate : 7.813 FPS (1024 SPF)
Compression mode : Lossy
Source stream size : 176 KiB (0%)
Language : English
