I’ve updated my Vero 4K last week and since then I’m not getting surround sound for videos with AAC 5.1/7.1 sound. Surround sound in videos with Dolby Surround and DTS works fine.
What is weird is that my AVR shows that it receives multi channel sound, but I only get sound from FL and FR speakers. It seems like Vero 4K sends multichannel sound, but all channels except FL and FR are silent. There is almost inaudible hiss from rest of the speakers, which starts when I start the video and disappears when I stop it, so they do become active.
I’m pretty sure it’s OSMC / Vero 4K problem, because when I disable passthrough and play a Dolby Surround video, there is no surround sound anymore. Before the update everything worked fine.
My AVR is Denon AVR-X1300W connected to Vero 4K through HDMI.
I know this. OSMC does decoding and sends multichannel LPCM output through HDMI. So you still get surround sound.
The issue is that after the last update all channels, except FL and FR, are silent in this case.
From the memory:
Output device: AML-<something>, HDMI
Number of channels: 7.1
Output configuration: Best match
Resample quality: High
I’ll make a screenshot of my audio settings this evening. But, as I said, non-passthrough surround sound worked fine before June update. I didn’t change any settings since then (neither in OSMC, nor on my AVR).
Sam I enabled Ac3 transcoding and it worked, but I had to specify my speaker setup being 2.0 instead of 7.1 and so now my receiver outputs 7.1 aac as 5.1 and but like you said, it’s just a temporary work around. AAC worked great for me before the update.
Same problem here. Had to select 2.0 to be able to select transcode in Kodi/OSMC. Solved the issue. Also solved the problem that my TV switched to another HDMI port (LG 55OLEDC7V). That was unexpected to say the least.
I have a Panasonic 58ax802 and I was experiencing that too, was wondering what was causing it. Hdmi 4 is my 4k input, and Vero was switching to HDMI1.
Also, and I know this is not of major concern currently, but with this problem, I have aac 7.1 movies, and with the workaround they output as 5.1. Any fix in the pipeline?
This might be CEC related; there’s been a few issues with active source changes (but they affect all platforms at this time unfortunately) and it is nothing unique to Vero 4K.
Once I get back from my trip, I’ll take a look (couple of days).
The main focus in the last update was fixing the popping noises and some Atmos issues (which are now thankfully gone).
