No audio when playback
Hi all
I have just got the Vero and found out that I have problems playing files that contains mp3 audio. I have seen it on several files.
Hope someone can help
Heres the media info.
Format : AVI
Format/Info : Audio Video Interleave
File size : 50.0 MiB
Duration : 5mn 9s
Overall bit rate : 1 355 Kbps
Writing application : Nandub v1.0rc2
Writing library : Nandub build 1852/release
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 5mn 9s
Bit rate : 1 227 Kbps
Width : 576 pixels
Height : 432 pixels
Display aspect ratio : 4:3
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.206
Stream size : 45.2 MiB (90%)
Writing library : XviD 0.0.09 (UTC 2003-03-25)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 5mn 9s
Bit rate mode : Variable
Bit rate : 116 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 4.28 MiB (9%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 477 ms
Can you upload a Kodi log?
Can you also ensure your audio settings have been configured properly in Settings?
What symptoms are you experiencing?
Hi Sam
Thanks for your swift reply. I am sure the audio settings are correct, as they worked for other files. It was only mp3 files.
I was expering symptoms where there were no audio, and some xvid files were stuttering.
However it is solved. I read in another post that they should update there OSMC package and after I tried that, it worked.
But thanks for your reply.
Can you provide mediainfo output for the file? Behavior is the same for all files?
Sorry, just realised I’d posted a complete log of everything, so removed the post. Should have checked how to do this first… Is there a way I can get the log URL removed? I will in meantime check media info for files not working and post them here…
Nah, your log was fine bud… I just included the link as it contains instructions for obtaining mediainfo.
Here are the media info exports for some files that don’t work. I’ve tried the MKV files with AAC and they play fine, as do MP4 or other containers that have mp3 soundtracks. It looks like its just MKV/MP3. They were all encoded in Handbrake/ Mac
Report for file: Brighton Rock - 1947.mkv
General / Container Stream #1
Total Video Streams for this File…1
Total Audio Streams for this File…1
Video Codecs Used…AVC
Audio Codecs Used…MPEG-1 Audio layer 3
File Format…Matroska
Play Time…1h 29mn
Total File Size…401 MiB
Total Stream BitRate…626 Kbps
Encoded with…HandBrake 0.9.8
Encoding Library…libmkv 0.6.5
Video Stream #1
Codec (Human Name)…AVC
Codec (FourCC)…V_MPEG4/ISO/AVC
Codec Profile…High@L3.0
Frame Width…720 pixels
Frame Height…544 pixels
Frame Rate…25.000 fps
Total Frames…134243
Display Aspect Ratio…4:3
Scan Type…Progressive
Color Space…YUV
Codec Settings (Summary)…3 Ref Frames
QF (like Gordian Knot)…0.052
Codec Settings (CABAC)…No
Codec Settings (Reference Frames)…3
Video Stream Length…1h 29mn 29s 720ms
Video Stream BitRate (Nominal)…507 Kbps
Bit Depth…8 bits
Video Encoder…x264 - core 120
Video Encoder (Settings)…cabac=0 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=abr / mbtree=1 / bitrate=507 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / vbv_maxrate=5500 / vbv_bufsize=5500 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Video Stream Language…English
Color Primaries…BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer Characteristics…BT.709-5, BT.1361
Matrix Coefficients…BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio Stream #1
Codec…MPEG Audio
Codec (FourCC)…A_MPEG/L3
Audio Stream Length…1h 29mn 29s 730ms
Audio Stream BitRate Mode…VBR
Number of Audio Channels…2
Sampling Rate…48.0 KHz
Audio Stream Language…English
Report for file: Buffalo '66 - 1998, Movie.mkv
Play Time…1h 45mn
Total File Size…478 MiB
Total Stream BitRate…635 Kbps
Encoded with…HandBrake 0.9.9
Video Stream #1
Frame Width…540 pixels
Frame Height…576 pixels
Total Frames…157777
Display Aspect Ratio…16:9
Color Space…YUV
QF (like Gordian Knot)…0.065
Video Stream Length…1h 45mn 11s 80ms
Bit Depth…8 bits
Video Encoder…x264 - core 130 r2273 b3065e6
Video Encoder (Settings)…cabac=0 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=abr / mbtree=1 / bitrate=507 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=5500 / vbv_bufsize=5500 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Color Primaries…BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM
Audio Stream #1
Codec…MPEG Audio
Audio Stream Length…1h 45mn 11s 80ms
Report for file: Russian Ark.mkv
Play Time…1h 35mn
Total File Size…439 MiB
Total Stream BitRate…645 Kbps
Encoded with…HandBrake 0.9.5
Encoding Library…libmkv 0.6.4.1
Video Stream #1
Codec Profile…Main@L3.0
Frame Height…400 pixels
Total Frames…142798
Color Space…YUV
Codec Settings (Summary)…CABAC / 4 Ref Frames
QF (like Gordian Knot)…0.069
Codec Settings (CABAC)…Yes
Codec Settings (Reference Frames)…4
Video Stream Length…1h 35mn 11s 920ms
Video Stream BitRate (Nominal)…497 Kbps
Bit Depth…8 bits
Video Encoder…x264 - core 112
Video Encoder (Settings)…cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=0 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=497 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Audio Stream #1
Codec…MPEG Audio
Audio Stream Length…1h 35mn 11s 932ms
Menu / Chapters Stream #1
Report for file: The Way Back.mkv
Play Time…2h 1mn
Total File Size…674 MiB
Total Stream BitRate…773 Kbps
Video Stream #1
Frame Height…436 pixels
Total Frames…182976
Display Aspect Ratio…2.35:1
Color Space…YUV
QF (like Gordian Knot)…0.083
Video Stream Length…2h 1mn 59s 40ms
Video Stream BitRate (Nominal)…650 Kbps
Bit Depth…8 bits
Video Encoder (Settings)…cabac=0 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=abr / mbtree=1 / bitrate=650 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=5500 / vbv_bufsize=5500 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Audio Stream #1
Codec…MPEG Audio
Audio Stream Length…2h 1mn 59s 27ms
Report for file: Scanners - 1981.mkv
Play Time…1h 36mn
Total File Size…495 MiB
Total Stream BitRate…715 Kbps
Video Stream #1
Total Frames…144994
Color Space…YUV
QF (like Gordian Knot)…0.076
Video Stream Length…1h 36mn 39s 760ms
Video Stream BitRate (Nominal)…590 Kbps
Bit Depth…8 bits
Video Encoder (Settings)…cabac=0 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=2 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=abr / mbtree=1 / bitrate=590 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=5500 / vbv_bufsize=5500 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Audio Stream #1
Codec…MPEG Audio
Audio Stream Length…1h 36mn 39s 770ms
Thanks - don’t think I can use mkvmerge as on Mac, but found MKVToolnix which has done the same thing as in thread. Cheers for yr help.
