when hitting Network File System (NFS) on the GUI I expect the GUI to show me my Synology. Instead it’s loading and then I’m back at the menu where to select for a new share.
There was a thread a short while ago where someone else was having access problems to a Synology box. Unfortunately, he’d tried all sorts of things (without success) and the state of his system had become a bit of a mess. That said, it might still be the case that Synology servers have too many idiosyncracies, though your Pi 2 clearly disagrees . It’s certainly true of Synology’s flavour of Linux.
If possible, I’d like to simplify the /etc/exports entries a bit. Can you see if:
unfortunately, it still has the same behavior, no change… So there is nothing I can do?
When I read the announcement the Vero 4K got out, someone was talking about Synology and NFS (which was working apparently). I’ll try to get in touch with him and see if he did something differently to get it work.
No – he was trying to change the UID for the OSMC user, which is absolutely unnecessary. In his situation, we were simply saying that OSMC follows the specification, Synology does not.
But in no way would that prevent him from streaming from a Synology NAS.
It will be a network issue or something wrong with the fstab mount.
As I recall, that was his first pitch, but when it became clear that it wasn’t possible, we explored other avenues but ultimately without a successful resolution to his problem…
So not OSMC. My psychic powers are clearly failing me today.
I had a quick read of the Kodi forum and it was being suggested that the insecure option should be used. I had to look it up and it’s for NFS connections on ports >=1024. I just tried an NFS mount using Kodi on my Vero 4K, but it’s using port 564, so the insecure option is not necessary, at least in my case…
tcp 0 0 osmc:564 192.168.8.3:nfs ESTABLISHED 987/kodi.bin
Can you drill down to a real file and show me the permissions?
to change the local file permission for everyone sounded promising, but neither read nor R/W (including apply to sub-folders) worked for me. I also tried a few exports (the one of my original post and the one @dillthedog mentioned in his posts) with the new permissions, no luck.
When you set the file permissions to everybody, other than ro, or rw, what other settings did you have. From looking at kodi wiki link you provided, it would be something like this:
