i just got my new vero4k and sold my Nvidia Shield because HDR was not working on the shield.
Samsung KS 7090 Firmware 1208 - Capable of 10 bit HDR Rec. 2020
Denon x1200 capable of hdr.
I tried both connecting the Vero4k directly to the televison and activated UHD at the right port.
And tried to connect the vero4k at my receiver Denon x1200w.
But no change at all the Display does not change into HDR mode and the brightness level went down as soon as i play a HDR file on my Vero4k colours are not HDR like…
If i play the Samsung Winderland demo.ts on my inbuilt TV player it works flawlessly the televison change the Display mode and the brightness went up and the colour are more intensive just as HDR should be.
Apologies for the late reply, something doesn’t look right here:
Display resolution ADJUST : 1920x1080 @ 60.00
If I’m reading the logs right for both these the adjust frame is playing these files at 1080p @ 60 fps, where as the mediainfo advises both of these are 4k and 23 fps.
Could you please provide the output of the following, when connected to the tv and then denon:
As @Tom_Doyle notes, it seems that your video is being played back as 1080p.
We’d need to see a complete Kodi debug log. Currently, it’s not possible to deduce what the problem is from your current logs.
I sometimes see a 4k video will not adjust to 4k and will play at 1080p on my Samsung KS9000. This is usually if the Vero has been on for days / weeks without a reboot. After a reboot it always switches to 4K properly. Have you tried a reboot? I’m sure you have but if not…
I leave the Vero ‘always on’, but it’s plugged into a receiver not the TV so it’s possible the receiver is on before the TV, so same scenario you explain.
