I have an audio problem with my Vero 4k +. When playing a movie with dts or hdma, dolby digital , true-hd my Arcam receiver jumps to digital 5.1 pcm.
Checked my audio settings many times.
It did work for the latest update.
What can this be?
Thanks in advance.
Regards,
Matthijs
Please post some debug logs so we can see what the issue is.
Hi Sam,
Is this the right log?
Thnx.
====================== guisettings.xml ===================
k2u3
2 December 2019 21:34
4
I’m pretty sure he wants you to do this
Overview
Sometimes things can go wrong. By collating and submitting a detailed bug report OSMC developers and the wider community can resolve the issue more quickly.
Where should you report these issues?
Unless it has been ascertained that the issue a confirmed bug in OSMC itself, GitHub should be avoided. We ask kindly that users initially use our support forum until it is indeed verified that the issue is caused by a bug in OSMC.
Please clearly explain the problem
In your report, please l…
Is the Vero plugged directly into your AVR through hdmi or is it configured in some other manner? If you had not seen it yet this thread may contain some useful info…
This wiki article should cover all your general questions about how to connect up your OSMC device to get the best audio possible. There’s also a section with explanations of some of Kodi’s audio settings as well as information about the audio capabilities of our OSMC devices.
Supported devices
OSMC supports a range of devices: All Raspberry Pis and our own Vero series (Vero 1, Vero 2, Vero 4K, Vero 4K + and Vero V).
Veros have an HDMI port for video and audio, a 3.5mm port for analogue au…
Also check Settings>Player>Videos>Sync playback to display> and make sure that is disabled.
Yes, directly through hdmi. Thnx for the link!
Problem solved! It was enabled.
Thnx!
