https://paste.osmc.tv/nunejebazu
https://paste.osmc.tv/oliserasoc
Sorry stupid me made a typo.
for sure it’s cat /etc/fstab | paste-log
also run mount | paste-log
fstab looks ok, so let try to figure out if the share is ok.
Can you run smbclient -U danielbachelay -L 192.168.0.254 and post the output
I get this : -bash: smbclient: command not found
Sorry thought it was installed.
sudo apt-get install smbclient
It seems to be ok, do you have a command line to show you ? Thanks
Not really, I assume you do this via ssh, or? Then you can just copy the terminal output.
Otherwise assuming that smbclient now shows “media” as a share and your fstab looks correct maybe just try to reboot
That’s expected, the smbclient command was just to cross check the share name
Ok, thanks, i’m gonna reboot it.
In Kodi, i just have to add sources as i did before, using SMB ? If so, i can’t, share not available after a reboot.
FYI, smb.conf is updated with “1”.
No, in Kodi you add them via local Filesystem (I think it is called root folder)
After reboot check with ls command if the share is mounted
Ok, i’ll try.
You mean “ls -lah /mnt/FREEBOX_media” ?
Yes
If still not working than just grab-logs -A
There is an option to add sources called Racine, Root in french, but i only access to the Vero 4K.
So I assume ls command also still says no directory?
Also was that the output of grab-logs -A? Because it is empty
Right : cannot open directory /mnt/FREEBOX_media: No such device
Ok than we need to get logs. Can you try again grab-logs -A and check if you get an output
Ok something still not working.
Aug 15 12:56:25 osmc systemd[1]: Got automount request for /mnt/FREEBOX_media, triggered by 967 (ls) Aug 15 12:56:25 osmc systemd[1]: Mounting /mnt/FREEBOX_media... Aug 15 12:56:25 osmc mount[968]: Retrying with upper case share name Aug 15 12:56:26 osmc mount[968]: mount error(6): No such device or address Aug 15 12:56:26 osmc mount[968]: Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) Aug 15 12:56:26 osmc systemd[1]: mnt-FREEBOX_media.mount mount process exited, code=exited status=32 Aug 15 12:56:26 osmc systemd[1]: Failed to mount /mnt/FREEBOX_media.
Really would be interesting to see what was the smbclient output. If you can not copy from your terminal can you take a picture with the mobile.
