Hi!
It seems that all PVR addons disappeared after update.
There is no more Enabled/Disabled addons category?
Thanks.
Hi!
Thanks.
Same problem here. Any solution for that ?
some info hereā¦
http://forum.kodi.tv/showthread.php?tid=232835
It has a new name ākodi-pvr-htsā
This is a key feature for me⦠hope we can fix it soonā¦
if i run āapt-cache search tvheadendā
I getā¦
xbmc-pvr-tvheadend-hts - XBMC PVR Addon TvHeadend Hts
armv6l-tvheadend-app-osmc - TVHeadend for OSMC
armv7-tvheadend-app-osmc - TVHeadend for OSMC
and āapt-cache search pvrā
ā¦
ā¦
I hope we can make a ākodi-pvr-htsā for osmc soonā¦
So what should I do to install IPTV Simple Client ? My girlfriend kills me when it is not working within the next 2 hours
a temporary solution for tvheadend
go to http://yourtvheadendserver:9981/playlist in your browser to download a channels.m3u
copy that to a drive you can access from osmc and now you have your channels
I donāt follow.
The binary addons should be bundled and included in this build. I tested myself and could see the PVR addons.
Addons -> Installed addons
I dont have -> Installed addons
my Addons look like thisā¦
My add-ons
Install from repository
Install from zip
search
system
and Iāve tried to search for āpvrā with no luckā¦
You do not need to install from a repository. Theyāre already installed. You also donāt need to install via apt-get.
Go to Settings -> Addons -> My Addons
I also have My add-ons
When I go to My Addons there is no PVR section
I see My Addons -> PVR clients here above Screensavers.
What device are you using and what version do you get in Kodi.log?
Iām using raspPi2
Starting Kodi (15.1-RC1 Git:Unknown). Platform: Linux ARM (Thumb) 32-bit
Using Release Kodi x32 build (version for Raspberry Pi)
Kodi compiled Aug 4 2015 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.7 (200711)
Running on Open Source Media Center 2015.07-1, kernel: Linux ARM 32-bit version 4.1.3-1-osmc
FFmpeg statically linked, version: 2.6.3-kodi-2.6.3-Isengard
Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
above Screensavers I just have Program add-ons , Iām using rp2
13:55:38 7.783212 T:1957105664 NOTICE: Starting Kodi (15.1-RC1 Git:Unknown). Platform: Linux ARM (Thumb) 32-bit
13:55:38 7.783278 T:1957105664 NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
13:55:38 7.783350 T:1957105664 NOTICE: Kodi compiled Aug 4 2015 by GCC 4.9.2 for Linux ARM (Thumb) 32-bit version 3.16.7 (2007$
13:55:38 7.783665 T:1957105664 NOTICE: Running on Open Source Media Center 2015.07-1, kernel: Linux ARM 32-bit version 4.1.3-1-$
13:55:38 7.783741 T:1957105664 NOTICE: FFmpeg statically linked, version: 2.6.3-kodi-2.6.3-Isengard
13:55:38 7.783803 T:1957105664 NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
Same here guys!
rpi 2, latest update, PVR stopped working, also canāt install the pvr iptv simple client.
maybe it is unrelated, but in the āapp storeā i can see the ātvheadendā service, which would allow some pvr service, i even cannot install that, dropping some error (maybe thatās why we cannot find the pvr menu as well)
The TVHeadend service from the App Store is not related to the PVR clients themselves.
It seems something may be wrong? Did you upgrade? From which version? Can you upload your apt.log?
Can confirm, I have RP2ās and have no PVRs available.
Haha, Iāve only recently converted every TV in the house to use OSMC with tvheadend running on an Intel 64 Ubuntu server with DVB-T2 and DVB-S2.
Iām going to be in the doghouse nowā¦
hey Sam!
Here is the full log: http://paste.osmc.io/japupewido
First i saw there is an update available (visually), that killed the PVR. I even tried to upgrade things after that from command line but it didnāt resolve it.
Upgraded from latest stable release (june).
Install/enable, same. I cannot make it work (activate/enable/install, whatever)
