Updating now will once again fix this issue
MySQL-Server is a Debian package provided by Debian apt mirrors - if you had problems updating this it suggests you have a more general problem with the network connectivity on your Pi. (Or Debian mirrors are having problems)
I am having the same issue, I just updated my osmc on my raspberry pi 1 model B, and lost live tv function. Even if I go under add-ons and try to enable it, there is no such option for PVRs. Only option for me to restore it back to Kodi 14 version of osmc however again with the update, I lost it.
Hi all,
does anyone know if this is an open issue for OSMC as Jan 16?
Simply IPTV Enabled - TV Enabled in Settings > No TV menu on main screen
( It seems the same issue reported by the first post, hope I am not wrong…)
This issue was solved some time ago. Would suggest a new post if you are experiencing this issue and let us know which device you are using
Hi Sam,
yes I will. Just chasing myself the problem a little more. Thanks for your reply.
Hi all! not sure if this the right place to ask for help. does anyone know how to setup pvr simple client in kodi to watch IPTV live television. I have kodi in Droibox and there are NO PVR adds-on at all.
This is a Kodi specific question. Check Kodi wiki or their forum.
