speaker test isn’t working
i mean it showing some info but it’s not the right sound the same with aplay
i just run a aplay -Ddefault:imxspdif filename.wav and it’s playing the same weird sound noises not the actual melody
Have been working on this. Does this help:
sudo apt-get update
sudo apt-get install vero-image-4.4.6-1-osmc
Setting up vero-image-4.4.6-1-osmc+rt13 (1) …
Running depmod.
Examining /etc/kernel/postinst.d.
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 4.4.6-1-osmc+rt13 /boot/vmlinuz-4.4.6-1-osmc+rt13
run-parts: executing /etc/kernel/postinst.d/inform-updater 4.4.6-1-osmc+rt13 /boot/vmlinuz-4.4.6-1-osmc+rt13
run-parts: executing /etc/kernel/postinst.d/process-vmlinuz-vero 4.4.6-1-osmc+rt13 /boot/vmlinuz-4.4.6-1-osmc+rt13
find: `/boot/dtb-4.4.6-1-osmc+rt13/’: No such file or directory
run-parts: /etc/kernel/postinst.d/process-vmlinuz-vero exited with return code 1
Failed to process /etc/kernel/postinst.d at /var/lib/dpkg/info/vero-image-4.4.6-1-osmc+rt13.postinst line 391.
dpkg: error processing package vero-image-4.4.6-1-osmc+rt13 (–configure):
subprocess installed post-installation script returned error exit status 2
After update to 08/16 - still no spdif sound
@sam_nazarko do you know if the issue was fixed ?
SPDIF sound issues were solved a long time ago. Start a new post if you have any issues
