I just got the May update and unfortunately since then my Wifi refuses to connect. Neither automatically, nor manually.
LAN still works fine.
Here’s what I did to reproduce the problem:
enabled debug logging
21:11 (local time) reboot
Wait until 21:14 - nothing happening, home router shows vero as disconnected. I am already connected via LAN though, so maybe it’s just not automatically trying to connect wifi
Go to MyOSMC network settings → wireless. Adapter is enabled, “Status: No wireless connection”. My Wifi network is shown in the list on the right
21:17 re-enable wireless adapter → “Status: No wireless connection”
21:18 manually select wifi network from the list and try to connect → asking for password (note, this time it asked instantly, when I rehearsed this before it took up to 2 minutes to even ask - not to mention that of course the password should be saved already)
NOTE: At this point (before entering the PW) my home router shows the Vero as connected and having its usual IP
21:21 Provide password → “Configuring…”
21:23 Pop up message “Connect to Wifi failed” → “Status: No wireless connection”
I just figured out a temporary solution. My Wi-Fi was encrypted with WPA3 with fallback to WPA2. Switching it to just WPA2 let me reconnect my Vero 4k to my Wi-Fi.
Not the solution I want for the future, but at least it works for now.
Hi, I got the same problem. I just updated half an hour ago and now wifi is not working anymore.
Actually I think my problem is different. I’m using WPA2 but after the update I can’t connect to any network at all. And there are some random error or the Vero is not responding if I gtry to connect.
Users only seem to be affected if they have WPA3 enabled on their router. If you don’t, then I suspect it’s a different issue, but without logs it’s hard to say.
I know Sam, but at the moment it is hard to replicate it because sometimes it just won’t connect without giving me an error.
Is there a way to just go back to the previous version and wait for another update in the future?
In the next days I have not much time and I just want to use the Vero for now.
Thanks in advance
Ah ok, Is it one of the .gz files?
Will this delete all of my skins, addons and Kodi settings?
And can I install it via USB? I have no other way to connect to the Vero due to the issue.
Thanks in advance
I am not sure which package is responsible for these messages. Presumably wpasupplicant changed but I am still investigating. With the version after the may update ( 2:2.9.0-21 ) I get these kernel messages
