I just tried to update as described via the OSMC-menue from November 2020 release to the latest August 2021 release. Unfortunately, neither my vero4k nor my vero4k+ is finding any updates.
Vero4k+ shorty tells something like “connectivity issue while trying to update”. I than tried to connect via SSH and start the update manually via “sudo apt-get update && sudo apt-get dist-upgrade && reboot” but did not succeed as the repositories seems to be too old (e.g. "Repository ‘http://security.debian.org buster/updates InRelease’ changed its ‘Suite’ value from ‘stable’ to ‘oldstable’).
Any ideas how I could update the November-Release?
Thanks, Tabaluga73
for not recognizing the FAQs. After applying the hotfix it worked perfectly!
