Press Y once and press enter.
I pressed Y… but then abort.
osmc@osmc:~$ sudo apt-get install git
Reading package lists… Done
Building dependency tree
The following additional packages will be installed:
git-man libcurl3-gnutls liberror-perl libgdbm3 libperl5.24 perl
perl-modules-5.24
Suggested packages:
gettext-base git-daemon-run | git-daemon-sysvinit git-doc git-el git-email
git-gui gitk gitweb git-arch git-cvs git-mediawiki git-svn perl-doc
libterm-readline-gnu-perl | libterm-readline-perl-perl make
Recommended packages:
patch rsync rename
git git-man libcurl3-gnutls liberror-perl libgdbm3 libperl5.24 perl
perl-modules-5.24
0 upgraded, 8 newly installed, 0 to remove and 0 not upgraded.
Need to get 11.2 MB of archives.
After this operation, 55.6 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Abort.
osmc@osmc:~$
an then i typed in this ssh command:
sudo systemctl start hyperionsudo systemctl start hyperion
osmc@osmc:~$ sudo systemctl start hyperion
Failed to start hyperion.service: Unit hyperion.service not found.
osmc@osmc:~$
Does it work with:
sudo apt-get -y install git
if not whats the output of:
df -h
Thanks Tom.
Lower case y
osmc@osmc:~$ sudo apt-get -y install git
perl-modules-5.24
Suggested packages:
patch rsync rename
perl-modules-5.24
Get:1 Index of /debian stretch/main armhf perl-modules-5.24 all 5.24.1-3+deb9u6 [2725 kB]
Get:2 http://security.debian.org stretch/updates/main armhf libcurl3-gnutls armhf 7.52.1-5+deb9u10 [263 kB]
Get:3 Index of /debian stretch/main armhf libgdbm3 armhf 1.8.3-14 [28.5 kB]
Get:4 Index of /debian stretch/main armhf libperl5.24 armhf 5.24.1-3+deb9u6 [2876 kB]
Get:5 Index of /debian stretch/main armhf perl armhf 5.24.1-3+deb9u6 [218 kB]
Get:6 Index of /debian stretch/main armhf liberror-perl all 0.17024-1 [26.9 kB]
Get:7 Index of /debian stretch/main armhf git-man all 1:2.11.0-3+deb9u5 [1433 kB]
Get:8 Index of /debian stretch/main armhf git armhf 1:2.11.0-3+deb9u5 [3663 kB]
Fetched 11.2 MB in 1s (10.6 MB/s)
Selecting previously unselected package perl-modules-5.24.
(Reading database … 24300 files and directories currently installed.)
Preparing to unpack …/0-perl-modules-5.24_5.24.1-3+deb9u6_all.deb …
Unpacking perl-modules-5.24 (5.24.1-3+deb9u6) …
Selecting previously unselected package libgdbm3:armhf.
Preparing to unpack …/1-libgdbm3_1.8.3-14_armhf.deb …
Unpacking libgdbm3:armhf (1.8.3-14) …
Selecting previously unselected package libperl5.24:armhf.
Preparing to unpack …/2-libperl5.24_5.24.1-3+deb9u6_armhf.deb …
Unpacking libperl5.24:armhf (5.24.1-3+deb9u6) …
Selecting previously unselected package perl.
Preparing to unpack …/3-perl_5.24.1-3+deb9u6_armhf.deb …
Unpacking perl (5.24.1-3+deb9u6) …
Selecting previously unselected package libcurl3-gnutls:armhf.
Preparing to unpack …/4-libcurl3-gnutls_7.52.1-5+deb9u10_armhf.deb …
Unpacking libcurl3-gnutls:armhf (7.52.1-5+deb9u10) …
Selecting previously unselected package liberror-perl.
Preparing to unpack …/5-liberror-perl_0.17024-1_all.deb …
Unpacking liberror-perl (0.17024-1) …
Selecting previously unselected package git-man.
Preparing to unpack …/6-git-man_1%3a2.11.0-3+deb9u5_all.deb …
Unpacking git-man (1:2.11.0-3+deb9u5) …
Selecting previously unselected package git.
Preparing to unpack …/7-git_1%3a2.11.0-3+deb9u5_armhf.deb …
Unpacking git (1:2.11.0-3+deb9u5) …
Setting up perl-modules-5.24 (5.24.1-3+deb9u6) …
Setting up libgdbm3:armhf (1.8.3-14) …
Setting up libperl5.24:armhf (5.24.1-3+deb9u6) …
Setting up git-man (1:2.11.0-3+deb9u5) …
Setting up libcurl3-gnutls:armhf (7.52.1-5+deb9u10) …
Setting up perl (5.24.1-3+deb9u6) …
update-alternatives: using /usr/bin/prename to provide /usr/bin/rename (rename) in auto mode
Processing triggers for libc-bin (2.24-11+deb9u4) …
Setting up liberror-perl (0.17024-1) …
Setting up git (1:2.11.0-3+deb9u5) …
osmc@osmc:~$ df -h
Filesystem Size Used Avail Use% Mounted on
devtmpfs 757M 0 757M 0% /dev
tmpfs 879M 8.5M 870M 1% /run
/dev/vero-nand/root 14G 5.1G 8.1G 39% /
tmpfs 879M 0 879M 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 879M 0 879M 0% /sys/fs/cgroup
/dev/sda1 316M 8.0K 316M 1% /media/B989-843E
tmpfs 176M 0 176M 0% /run/user/1000
osmc@osmc:~$
You need to follow the instructions properly. You now need to clone the repository.
how can i clone the repository?
im sorry but i am an absolutely beginner
Just follow all of hissingshark’s steps, your are missing steps (2, 3 and 4)
omg thank you very much for your help. now i can open the web configuration.
what is the next step to start the ambilight on kodi for my movie files?
The web GUI has a “Remote Control” tab.
Set the grabber as the active source and it will run, regardless of whether you’re in the Kodi menus or playing a file.
@hissingshark i set the grabber as the active source but no led lights.
do i have to change any other settings like baudrate or anything else?
btw i bought this ambilight kit from aliexpress
Absolutely. I assumed you’d been using Hyperion on a prior installation.
In the hardware configure you’ll need to tell it the number and position of the LEDs and the driver details which yes, includes the baud rate.
i typed in the correct number and position of the led´s already.
how did i get the info for the correct driver details and baudrate?
is there any config file that i can import?
i really thank you very much for all to help a very noob like me
To judge by the screenshots on the product website and some Amazon reviews you could try selecting Adalight as the “Controller type” and 115200 as the baud rate.
If that doesn’t work try some searches for Hyperion and your product (Light Box Dream Color).
i changed to adalight and baudrate to 115200 but still not working.
The product page refers to installation compatible with “Raspberry Pi: Openelec/libreelec+Hyperion”, so you mileage may vary here.
Importantly it also links to this video. It is old, showing a setup with Hyperion “classic”, rather than NG as we use these days, but I don’t think that should matter.
There they have used Adalight and 115200 - but with/dev/ttyUSB0 as the output device, which is different to our Adalight default of /dev/ttyACM0, so try that.
thank you. i will try it.
yes… i changed to /dev/ttyUSB0 and now the leds are lightning. but the colors are not correct. blue is white and purble is green an so on… if i start the movie the ambilight not change the colors
now the colors are correkt if i watch a picture.
but if i start a video, my nero reboot with a bad smiley
