It was the only command I found while searching how to run Hyperion in debug mode.
Just happened again tonight. I’ve been watching things on and off all week without issue then tonight pressed stop after a film finished and now the Vero is not responding. Not even to ping.
Yes I am using Amlogic.
Will reboot and stop the service and run it from SSH with that command.
What does not show up is that the last line is a series of 26 NULL characters.
A little on how I am using Hyperion:
When playback is stopped or paused for 5 minutes or if I switch TV sources away from Kodi, Home Assistant turns off Hyperion (hence the no carrier lines).
If the TV source is changed to Kodi or playback begins Hyperion is switched on.
I also have a second integration set up for WLED in Home Assistant that may be causing issues.
I’m going to try the following:
1: Disabling the Home Assistant WLED integration (I don’t use it anyway).
2: Switching off the LEDs instead of Hyperion. There’s an issue about this on the Home Assistant Hyperion integration Github repository. https://github.com/home-assistant/core/issues/41892 that provides a method for doing this.
EDIT: ok, time will tell if this makes a difference (LEDs off after 5 minutes of no playback):
2021-09-22T01:05:05.264Z [hyperiond AMLOGICGRABBER] (DEBUG) (AmlogicGrabber.cpp:198:grabFrame_amvideocap()) Video playback has been paused
2021-09-22T01:05:22.665Z [hyperiond AMLOGICGRABBER] (DEBUG) (AmlogicGrabber.cpp:198:grabFrame_amvideocap()) Previous line repeats 1 times
2021-09-22T01:05:22.666Z [hyperiond AMLOGICGRABBER] (ERROR) Read of device failed: 61 - No data available
2021-09-22T01:05:22.687Z [hyperiond AMLOGICGRABBER] (INFO) Switch to Framebuffer capture mode
2021-09-22T01:10:22.875Z [hyperiond LEDDEVICE] (DEBUG) (LedDeviceWled.cpp:237:powerOff()) Restore synchronisation with other WLED devices
2021-09-22T01:10:22.877Z [hyperiond COMPONENTREG] (DEBUG) (ComponentRegister.cpp:36:setNewComponentState()) LED device: disabled
I assume the sending of UDP packets is stopped when the LED device is turned off?
As a follow up, I ended up removing the WLED integration from Home Assistant and leaving the Hyperion integration as is (switching Hyperion, not the LEDs).
We strongly recommend doing an export of your configuration before migrating to the new version!
You cannot use the new version’s configuration database with a previous version.
If you run multiple instances, you unfortunately need to export each individually.
I am building a new installation and would appreciate some recommendations.
My planned scheme is:
[Vero 4k with hyperion-vero4k] --Ethernet-- [Raspberry Pi with HyperBian] --SPI-- [LED strip]
I want to grab image on Vero and forward it to out to LED on Pi.
On the Pi side i’ve configured “LED Output” (Controller, Layout) and “Network Services” (JSON Server, Flatbuffers Server). “Screen Capture” is ready on the Vero side.
But what is proper config for hyperion on the Vero to forward data to Pi? Would be enough to configure “Forwarder” with “flat” and “json”? Or “LED Output” must be configured on the source server too?
UPD: works like a charm without additional config, thanks to @hissingshark and all committers!
I’m using hyperion fork HyperHDR now for a while now.
Got today my Vero 4k+ installed hyperion on it but i notice the internal grabber is quit laggy. Am I missing something? Decimation was on almost 20% and stil no luck.
Cause i don’t think it has any value of using if the grabber doesn’t give a solid video.
I’m thinking going back to hardware grabber like i’m using already and buy myself a extra hdmi splitter
It’s a shame the HDR support stalled. I took a look at HyperHDR and got it to build. But it doesn’t support internal grabbers so you’d have to buy a USB unit. I also don’t like the fact they forked the project, but I guess that’s the way it goes.
I’ve updated the builds to include it. No idea if it’ll do what you want. Let us know.
I did observe that it defaults to off in the webGUI, so you’ll need to toggle it on there.
And of course if you think it needs anything else adding you can always try building it from source yourself and test it. That is why I built the installer with all those menus and options!
Thanks. I don’t even use it. Home Assistant just checks that it is disabled and generates an error if it can’t find it. Also sorry, I forgot about the build it yourself option
Hey Peeps.
Been using 1.0.0 for years now but switching to new 4K+
I am a bit overwhelmed by this thread on where to find a “how to”.
I scrolled a few hundred posts down from 1, but it looks outdated.
Scrolling a few hundred up only gave troubleshooting things.
Of course I used the search function, but most posts are error related.
Did I miss something obvious here?
I’m still enjoying my hyperion ambilight every single day at it’s been rock solid and an easy installation everytime I start fresh thanx to your awesome installer…
The Debian 11 update and upgrade to Python 3.9 breaks it at the moment though, as install.sh still references 3.7
I’ve replaced Python-* 3.7 with 3.9 and was able to successfully build an run hyperion again.
I already zipped the binaries and will share them with you if you like (and trust me of course)…
As I’m not running any dev-machines at the moment I can’t make a pull request, but as you know it’s an easy fix.
For anyone interested:
Just replace all Python* 3.7 references with 3.9 or just overwrite the respective lines in install.sh
