Hi all,
just received the osmc bluetooth USB dongle, but it seems not to be working.
In the OSMC app under network is not a bluetooth menu and with dmesg I can see the following:
[89979.365795] usb 1-1.1.3: new full-speed USB device number 17 using dwc_otg
[89979.805808] usb 1-1.1.3: device not accepting address 17, error -32
[89979.805984] usb 1-1.1-port3: unable to enumerate USB device
Any ideas to get the dongle working?
May be that I received a faulty dongle?
Fabian
Are you using the latest version of OSMC? Which device are you using the dongle on?
Hi Sam,
no, I‘m staying on Leia with Pi3 b+ because of hyperion is not working on newer builts.
That could be the problem.
Is the dongle not compatible with the latest Leia built?
Hard to say – you are probably on a version from 2019, that’s quite old and not something we officially support.
