The other day i was watching a movie on my tv and when i was done i forgot the take off the # so my 800x480 screen from Adafruit could show the video correctly on that screen. After noticing my mistake i try to correct it but every time i add this
Could the boot partition be full and therefor reject changes? Should give off error in saveing in nano tho. Did you try to add a file in /boot or osmc dir?
Joakim_Sandstrom i copied a file directly to the sd card by plugging in the micro sd to my raspbian and selecting a audacity file i had on my desktop. Then put the sd card back in my b+ and boot it, then reboot, shutdown, insert it back into raspbian to check and it was still there with the same 17.9kb it had when i copied it over
No error comes up in nano, it saves changes like it should. But apon inspecting the config file in piconfi like in image 5 it gives me that duplicate thing and deletes the hdmi_mode=87. But if i don’t check it in piconfig and check it in nano or on raspbian first my changes like in image 4 are there
Just because you save it and it looks fine when you then view it, you’re probably getting it from the file cache, and not the saved version from the SD card.
