Hello, run to a problem after running manual-update command , it the update installed successfully but it is not running keeps blinking with the blue background with a sad emoji, help??
https://paste.osmc.tv/eyujakenoz
RPi 2b+
RPi 2b+
If you can ssh in, please send us logs using
grab-logs -A
It looks like something in your user profile got screwed up. I would try renaming your .kodi folder and see if it will boot with a fresh profile…
mv ~/.kodi ~/kodi.bak
Can you tell us exactly what you did to ‘manually-update’? And what were you trying to achieve?
It looks like you’ve used Berryboot:
Linux version 4.14.83v7-aufs
/dev/mmcblk0p2 /media/berryboot ext4 rw,nosuid,nodev,relatime,data=ordered 0 0
As far as I know, Berryboot isn’t supported. @sam_nazarko should be able to clarify the current position.
We don’t support BerryBoot installations.
i have been using berryboot with osmc for a long time,it work well,
i gave up , started fresh osmc and now customizing it
but when i run kodi in the terminal it executes successfully
sry late reply my account was on hold
