Hi guys,
Was currently on the October update, thought I’d run a manual update and see if there was any updates through the My OSMC manual update check.
It downloaded an update and successfully installed without interruption or errors.
After rebooting Into my Aeon MQ8 skin, I’m seeing ‘OSMC failed to start’.
I’ve tried starting the program manually through the menu but it just won’t start.
The system also fails to play any type of content.
Any suggestions or guides for a complete newbie? Note: anything involving terminal or command line I’ll need basic easy to follow instructions
