OSMC Foregets my WIFI Password
I’m using the latest OSMC on a Pi4. I’ve had this problem since I started using OSMC. Sometimes my WiFi glitches (I hear the notification sound from OSMC) and then it reconnects (another notification sound) and OSMC looses the WiFi connection. When I go to reconnect through MyOSMC I have to reenter the password which is a PITA because it’s a long password. Why doesn’t OSMC remember my password? Is there anything I can do to store the password permanently?
You could try connecting via the command line using connmanctl
Logs might show why the password is not remembered. Maybe the MAC is changing on the AP for some reason? This would explain the dropouts
How do I connect to wifi from the command line using connmanctl?
thanks.
