I’ve now got a workaround that should let people watch most IPTV packages without any problems.
- Login via the command line
- Edit the file
/etc/apt/sources.list - Add the following line:
deb http://apt.osmc.tv jessie-devel main - Run the following commands to update:
sudo apt-get update && sudo apt-get dist-upgrade && reboot - Your system should have have received the update.
If this solution stops working, let me know. It’s possible for us to change the user agent in the future or even pick one from a selection at random. This would make it very difficult to block as if they were to do so they’d be blocking other popular platforms, i.e. Windows as well.
