OSMC on Raspberry PI. Won't start IPTV streams
Hi, hope someone can help.
I am a new users to OSMC / Kodi on Raspberry PI 2. I have to say I have been amazed at how well the platform works and have been delighted with what I have running so far however, I have run into a slight problem.
I am looking to get some IPTV streams running. I have followed the process to Enable TV, Enable the Simple IPTV client and configure the m3u list to get the channels. All of this seems to work, however, none of the actual channels actual work. I get the “Working” spin dial for a couple of seconds and then nothing.
The same process works fine on other installs of kodi that I run, I just can’t get it to work on the PI.
Any help would be appreciated, thanks in advance.
To get a better understanding of the problem you are experiencing we need more information from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us.
Just had a tiny look into this myself and spotted the difference between this working on a windows version of kodi and it not working on the PI version.
here are the entries I noticed (I have blanked out the username and password but trust me they are the same):
I’ve had to modify my post as I can’t post more than 3 links in a post but instead of getting
Good
DEBUG: PVRManager - PVR::CPVRManager::OpenLiveStream - opening live stream on channel ‘BBC 1’
DEBUG: opening live stream on url ‘http://portal.rapidiptv.com:8080/live/xxxxxxxx/xxxxxxxx/3580.m3u8’
DEBUG: PVRFile - XFILE::CPVRFile::Open - playback has started on filename pvr://channels/tv/All channels/pvr.iptvsimple_869778546.pvr
DEBUG: CFileCache::Open - opening <live/xxxxxxxx/xxxxxxxx/3580.m3u8> using cache
DEBUG: CurlFile::Open(0B577038) http://portal.rapidiptv.com:8080/live/xxxxxxxxxx/xxxxxxxxxx/3580.m3u8
INFO: XCURL::DllLibCurlGlobal::easy_aquire - Created session to http://portal.rapidiptv.com
DEBUG: CCurlFile::Open - effective URL: http://95.154.222.14:8080//streaming/clients_live.php?username=xxxxxxxxxx&password=xxxxxxxxxx&stream=3580&extension=m3u8&hash=11515dc2c5d16ef442136a9ce343d59c&time=0&pid=32482&external_device=
NOTICE: Thread FileCache start, auto delete: false
INFO: CFileCache::Process - Hit eof.
I get (had to cut most out)
PVRManager - OpenLiveStream - opening live stream on channel ‘BBC 1’
DEBUG: opening live stream on url blah blah blah
DEBUG: PVRFile - Open - playback has started on filename pvr://channels/tv/All channels/pvr.iptvsimple_869778546.pvr
DEBUG: CFileCache::Open - opening <live/xxxxxxxxxx/xxxxxxxxxx/3580.m3u8> using cache
DEBUG: CurlFile::Open(0x661efbf8) blah blah blah
INFO: easy_aquire - Created session to blah blah blah
DEBUG: PushCecKeypress - received key b duration 269 (rep:0 size:0)
DEBUG: PushCecKeypress - ignored key b
ERROR: CCurlFile::Open failed with code 404 for
ERROR: Open - failed to open source
How can what you are trying to do here be legitimate? 2400 channels? This is like EVERY channel on the planet…
18:59:47  13.290298 T:1751118880  NOTICE: AddOnLog: PVR IPTV Simple Client: Loaded 2399 channels.
18:59:47  13.301758 T:1751118880   DEBUG: CAddonCallbacksAddon - QueueNotification - PVR IPTV Simple Client - Info Message : '2399 channels loaded.'
18:59:48  15.242423 T:1759507488   DEBUG: PVRChannelGroup - Load - 2398 channels loaded from the database for group 'All channels'
18:59:49  15.351936 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'SPORTV 5 HD'
18:59:49  15.352166 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Premium Crime HD'
18:59:49  15.352303 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'BeinSport6'
18:59:49  15.352426 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'M6 MUSIC'
18:59:49  15.352548 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'FR TREK'
18:59:49  15.352661 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'History Channel'
18:59:49  15.352770 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Anomalisa [2015]'
18:59:49  15.352881 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Pink 2'
18:59:49  15.352983 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'NatGeoRussia'
18:59:49  15.353089 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'PassionXXX'
18:59:49  15.353254 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'SuperSport Kosova 2'
18:59:49  15.353463 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'SKY slecet 6'
18:59:49  15.353584 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Bindass Play'
18:59:49  15.353684 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'NAT GEO WILD'
18:59:49  15.353782 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Film Hits Plus 1'
18:59:49  15.353879 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'RTV Islam'
18:59:49  15.353968 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Eska Wawa Tv'
18:59:49  15.354056 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Fox Sports 2'
18:59:49  15.354147 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'FTV'
18:59:49  15.354248 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'MOV HD'
18:59:49  15.354358 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'RTV 21 Popullore'
18:59:49  15.354465 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Kutia TV'
18:59:49  15.354579 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Hayatovci'
18:59:49  15.354696 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'RTL 4'
18:59:49  15.354809 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'The Good Lie [2014] [DE]'
18:59:49  15.354921 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'OSN ALYOUM'
18:59:49  15.355036 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'RTL Kockica'
18:59:49  15.355139 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Rave TV ( Nigeria )'
18:59:49  15.355247 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky Sport F1'
18:59:49  15.355350 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'POP'
18:59:49  15.355452 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Avengers Age of Ultron [2015] [DE]'
18:59:49  15.355556 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Klan HD'
18:59:49  15.355658 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Turist [2014] [DE]'
18:59:49  15.355755 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'OSN BOX OFFICE 3'
18:59:49  15.355864 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Cartoon Network (N)'
18:59:49  15.355972 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'ZAYTOONA'
18:59:49  15.356076 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'N24 HD'
18:59:49  15.356183 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Rai 2 HD'
18:59:49  15.356291 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Vremya'
18:59:49  15.356400 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Pink Folk 2'
18:59:49  15.356503 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Stv 2'
18:59:49  15.356609 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'CANAL PLUS CINEMA HD'
18:59:49  15.356800 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'AAA FAMILY'
18:59:49  15.356919 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Discovery Investigation'
18:59:49  15.357117 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Emmanuel TV ( Nigeria )'
18:59:49  15.357237 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'SonY Us'
18:59:49  15.357341 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TRT Bugun TV'
18:59:49  15.357438 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel '92 HD 2'
18:59:49  15.357535 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TVR 1'
18:59:49  15.357627 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Tring World'
18:59:49  15.357724 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Comedy Central'
18:59:49  15.357822 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Animal Planet'
18:59:49  15.357920 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'FR Gulli'
18:59:49  15.358012 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'beINSport 2 HD (UEFA CHAMPIONSHIP)'
18:59:49  15.358106 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TV1000 Comedy'
18:59:49  15.358200 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'History Channel'
18:59:49  15.358295 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'It Follows [2014] [AL]'
18:59:49  15.358388 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky Primafila 8 HD'
18:59:49  15.358480 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'BN Sat'
18:59:49  15.358573 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'A LA CARTE 1 HD'
18:59:49  15.358668 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Fox Crime HD'
18:59:49  15.358764 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'BEINSPORT11'
18:59:49  15.358861 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Pink Romance'
18:59:49  15.358961 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'MBC Pro3'
18:59:49  15.359057 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Klan Plus'
18:59:49  15.359159 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Moviestar F1'
18:59:49  15.359260 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky Calcio 1 HD'
18:59:49  15.359361 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'HBO COMEDY'
18:59:49  15.359467 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'BT Sports 1 HD'
18:59:49  15.359591 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'RTS 1'
18:59:49  15.359702 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'US ESPN 1'
18:59:49  15.359815 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'ORF Eins'
18:59:49  15.359935 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sport1 Golf HD'
18:59:49  15.360143 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'GEO TV'
18:59:49  15.360425 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky Germany BUNDESLIGA 1 HD'
18:59:49  15.360559 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sy-Fy'
18:59:49  15.360766 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky Germany BUNDESLIGA 10 HD'
18:59:49  15.360895 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Premium Sport HD'
18:59:49  15.361004 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'CINE 5'
18:59:49  15.361122 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'American Sniper [2014] [AL]'
18:59:49  15.361229 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'The Wedding Ringer [2015]'
18:59:49  15.361341 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Setanta Sport'
18:59:49  15.361452 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'ART CINEMA'
18:59:49  15.361571 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'FILM KOMEDI'
18:59:49  15.361684 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'France O HD'
18:59:49  15.361792 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Die Coal Valley Saga - Versteckte Wahrheit [2014] [DE]'
18:59:49  15.361905 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'RTE 1 HD'
18:59:49  15.362028 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'France 4'
18:59:49  15.362146 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Nat Geo Wild'
18:59:49  15.362258 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Eurosport2'
18:59:49  15.362360 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'The Longest Ride [2015] [DE]'
18:59:49  15.362462 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Premium Calcio 2'
18:59:49  15.362563 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TRT 1 HD'
18:59:49  15.362663 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Dr Ramasjang'
18:59:49  15.362764 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Juventus Channel'
18:59:49  15.362866 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'NRJ 12'
18:59:49  15.362961 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Star Plus'
18:59:49  15.363070 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'MRTV 2'
18:59:49  15.363174 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Tring Sport 2 HD'
18:59:49  15.363276 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Polsat Sport Extra HD'
18:59:49  15.363374 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'J Max'
18:59:49  15.363470 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'MTV Dance'
18:59:49  15.363563 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Bang Bang'
18:59:49  15.363656 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel '92 HD'
18:59:49  15.363752 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'RTV 21 PLUS'
18:59:49  15.363841 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Canal PLUS'
18:59:49  15.364004 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Teleclub Sport 1'
18:59:49  15.364099 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Film GOLD 2'
18:59:49  15.364192 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TSN3'
18:59:49  15.364368 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Roma Channel'
18:59:49  15.364470 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'K SPORT3'
18:59:49  15.364563 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'KANAL 5'
18:59:49  15.364655 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'True Movies 2'
18:59:49  15.364750 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'SKY CINEMA COMEDY HD'
18:59:49  15.364845 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Living HD'
18:59:49  15.364943 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky select 5 HD'
18:59:49  15.365035 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Amedia2'
18:59:49  15.365131 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'ArenaSport 5 SRB'
18:59:49  15.365229 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Polsat Viasat History'
18:59:49  15.365319 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TVN24'
18:59:49  15.365410 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Comedie Plus HD'
18:59:49  15.365503 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'FR Science et Vie'
18:59:49  15.365596 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'POLSAT SPORT'
18:59:49  15.365685 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'BOOMERANG'
18:59:49  15.365777 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky Movies ShowCase'
18:59:49  15.365868 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'OSN Ya Hala Drama'
18:59:49  15.365962 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'T Stinet'
18:59:49  15.366067 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TV Super Sky'
18:59:49  15.366171 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Tring Comedy'
18:59:49  15.366264 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'STSMoskva'
18:59:49  15.366355 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'OSN Ya Hala HD'
18:59:49  15.366447 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Inside Out [2015]'
18:59:49  15.366546 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'HBO SIGNATURE'
18:59:49  15.366639 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TVR Cluj'
18:59:49  15.366728 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky select 1 HD'
18:59:49  15.366820 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'SKY CINEMA 1 HD'
18:59:49  15.366915 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Disney Junior'
18:59:49  15.367009 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'The Diary of a Teenage Girl [2015]'
18:59:49  15.367176 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'DISCOVERY'
18:59:49  15.367273 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TV Globo Premium'
18:59:49  15.367366 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TVCine 2 HD'
18:59:49  15.367524 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'MiniMax'
18:59:49  15.367624 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky Moto GP'
18:59:49  15.367720 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'IRIB MOSTANAD'
18:59:49  15.367810 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'IRIB VARZESH'
18:59:49  15.367901 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'CINE 9'
18:59:49  15.367994 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'AXN +1'
18:59:49  15.368087 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'PEACE TV'
18:59:49  15.368193 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'BeinSport1'
18:59:49  15.368298 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'PARAMOUNT'
18:59:49  15.368416 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'beINSport 10 HD'
18:59:49  15.368525 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Nasul TV'
18:59:49  15.368630 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Vevo TV 1'
18:59:49  15.368731 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Terminator Genisys [2015] [DE]'
18:59:49  15.368837 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky Sport 1 HD'
18:59:49  15.368945 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TV Republika'
18:59:49  15.369052 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'MBC DRAMA'
18:59:49  15.369162 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky Emotion'
18:59:49  15.369265 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'premiera'
18:59:49  15.369369 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'The Martian [2015]'
18:59:49  15.369469 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'CINE 12'
18:59:49  15.369569 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'ROTANA MASRIYA'
18:59:49  15.369678 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'HRT 3'
18:59:49  15.369780 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'SPORTING HD'
18:59:49  15.369872 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Sky Hits'
18:59:49  15.369976 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Ciné Plus Famiz HD'
18:59:49  15.370221 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Film 4'
18:59:49  15.370338 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TV8 SW'
18:59:49  15.370446 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'POLSAT2 HD'
18:59:49  15.370544 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Setanta Sport'
18:59:49  15.370728 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'The Lego Movie [2014] [DE]'
18:59:49  15.370839 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Discovery Science'
18:59:49  15.370942 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'MAKAH LIVE'
18:59:49  15.371048 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'OCS CITY'
18:59:49  15.371252 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'TVI 24'
18:59:49  15.371378 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'AL JANOUBIA'
18:59:49  15.371479 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Gulli'
18:59:49  15.371583 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Pink Thriller'
18:59:49  15.371700 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Perviykanal'
18:59:49  15.371806 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Aapkaus'
18:59:49  15.371906 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Atn Bang'
18:59:49  15.372017 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'SportTV 5'
18:59:49  15.372121 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Look TV'
18:59:49  15.372229 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'FR MANGAS'
18:59:49  15.372343 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Inedit TV'
18:59:49  15.372443 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'tv1000'
18:59:49  15.372536 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'NBC E.P.L XTRA 7 (LIVE DURING EPL)'
18:59:49  15.372634 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'CAIROCINEMA'
18:59:49  15.372738 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'SuperSonic TV'
18:59:49  15.372835 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'OCS Max HD'
18:59:49  15.372929 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'OSN Ya Hala'
18:59:49  15.373027 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'SportPlus'
18:59:49  15.373131 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Discovery Channel'
18:59:49  15.373232 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'NRJ 12 HD'
18:59:49  15.373329 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Al Maghribia'
18:59:49  15.373423 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Shop24Direct'
18:59:49  15.373523 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'SAMAA TV 2'
18:59:49  15.373629 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Polsat Sport News'
18:59:49  15.373722 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'Nick JR'
18:59:49  15.373809 T:1759507488    INFO: PVRChannelGroupInternal - AddAndUpdateChannels - updated TV channel 'E! Entertainment'
I could cut it down to one channel, the point of my support request is that 1 channel or 2399 channels it still doesn’t work.
If you have purchased these streams from someone, you need to ask them, it’s not an OSMC issue.
I guess what he wants to tell you is that you will not get assistance on this forum if your intend is to view every tvchannel on the planet without paying for it.
Even if this might be in a grey area, the osmc team is not there to assist with this.
Ok, I apologise if I have compromised anyone or the forum by asking for help on this. That was definitely not my intention.
I have removed the post showing the full service capabilities.
My apologies once again.
This won’t help us resolve the issue, as it almost solely revolves around whomever you purchased this service from.
Ask them for support. Not us. There is absolutely nothing we can do.
Hello,
@sam_nazarko, are you sure that it’s not related with OSMC+KODI and therefore that you can’t help us?
We are 4 colleagues that are suffering the same problem with our PIs and IPTV Simple Client Addon.
The same IPTV source is playing correctly on Appletv, Windows 10, Android 5.1, Android 6.0, with multiple different IPTV clients, and we only face the problem with our PIs+OSMC+Kodi.
I also tested different OSMC releases available on the OSMC installer, with the same result, a 404 error, that is not faced at the same time with different OSs mentioned above, pasting the URL from the kodi.log error log to avoid any typing mistake.
I found the following information that it seems related:
If you also find tat it’s related, can you please take a look at the issue and check if that patch could fix the issue?
Best regards and thanks in advance,
Joseba M. Iturbe
Where is the log? And what is the source of your IPTV links?
Hello @ActionA,
Thanks for answering so fast.
Here is the tail -f .kodi/temp/kodi.log when trying to view a Channel:
00:31:08 157.458359 T:1957245872 NOTICE: DVDPlayer: Opening: pvr://channels/tv/Todos los canales/pvr.iptvsimple_396307374.pvr
00:31:08 157.458679 T:1957245872 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
00:31:08 157.459869 T:1528816624 NOTICE: Creating InputStream
00:31:10 158.914307 T:1528816624 ERROR: CCurlFile::Open failed with code 404 for http://vipserver.dynamic-dns.net/live/xxxxx/xxxxx/12733.ts
00:31:10 158.914627 T:1528816624 ERROR: Open - failed to open source http://vipserver.dynamic-dns.net/live/xxxxx/xxxxxxx/12733.ts
00:31:10 158.914993 T:1528816624 ERROR: CDVDInputStreamPVRManager::Open - error opening [http://vipserver.dynamic-dns.net/live/xxxxx/xxxxxxx/12733.ts]
00:31:10 158.915268 T:1528816624 ERROR: CDVDPlayer::OpenInputStream - error opening [pvr://channels/tv/Todos los canales/pvr.iptvsimple_396307374.pvr]
00:31:10 158.915390 T:1528816624 NOTICE: CDVDPlayer::OnExit()
00:31:10 158.924927 T:1957245872 NOTICE: CDVDPlayer::CloseFile()
00:31:10 158.925171 T:1957245872 NOTICE: DVDPlayer: waiting for threads to exit
00:31:10 158.925262 T:1957245872 NOTICE: DVDPlayer: finished waiting
00:31:10 158.925446 T:1957245872 NOTICE: CDVDPlayer::CloseFile()
00:31:10 158.925552 T:1957245872 NOTICE: DVDPlayer: waiting for threads to exit
00:31:10 158.925659 T:1957245872 NOTICE: DVDPlayer: finished waiting
Copying that URL on waterfox/firefox over W10, you are redirected to:
http://85.17.14.10:8000//streaming/clients_live.php?username=xxxxx&password=xxxxxxxx&stream=12733&extension=ts&hash=f7ea6d660ccfb726c42ec9069d8e1c35&time=1473892527&pid=61042&external_device=&on_demand=0&bitrate=6744
And the channel is played perfectly.
Best regards,
We need complete logs. You also have not answered the second question. What is the source of the IPTV links?
Hi @ActionA,
You have the source on the tail. It’s an authenticated streaming tv source (I removed the login & password). The URL is the only info I have.
I’ll send the complete log asap.
Thanks for your support and best regards,
Joseba
Hello @ActionA,
The URL to complete log is (removed login/password from http requests):
http://paste.osmc.io/inacubewef.vhdl
The log corresponds to an osmc restart, PVR launch and selection of two different channels.
The source of the IPTV streams can be seen on the log. I have no other info apart from the URL.
As additional information, I checked that it also works properly on kodi over Android 6 running into an nvidia shield tablet.
Thanks in advance,
20:29:51 194.945282 T:1594881008   ERROR: CCurlFile::Open failed with code 404 for http://vipserver.dynamic-dns.net/live/xxxx/xxxx/12732.ts
Looks like a connectivity problem. Try changing your DNS.
I can see the source URL, yes. What I want to know is who provides you with this IPTV service?
I know nothing about the IPTV provider, just found the service on a forum. Does it matter anyway?
It’s not a DNS problem. I checked any connectivity issues before asking for help. The name resolution under OSMC is working (I’m an experienced unix sysadmin).
The access to this streams is not blocked by my internet provider as I’m seeing the streams on many other devices through the same internet access line at my home (Android+Kodi, Android+other clients, windows, Apple TV,…).
I also tested on different PIs (2 & 3), with different access lines, with almost every Kodi release available through OSMC installer,…without luck. Same result every time.
To focus the root cause of the problem, just tell you that I can download the videos on my PI+kodi+osmc with a simple wget to the URL and I’m able to open these downloaded stream videos, so it seems the problem is located on the PI+OSMC+KODI+PVR+IPTV Simple client.
I would say that it’s a problem with redirected streams, and that’s why I started searching this topic and found the issue I posted before:
Do you think it could be the same problem?
Thanks for your help and best regards,
If you try a Kodi Krypton test build and the problem disappears, then you may have your answer
Hello,
This was my first approach, but the test builds still have many issues, and it seems I had very bad luck as all the PVR stuff is missing on the latest test builds…
http://forum.kodi.tv/showthread.php?tid=265306&page=11
I tested by myself that PVR is not working on the latest build and had to rollback to Jarvis.
I could do the all the testing on my Kodi Jarvis if I had a patched VideoPlayer, or also compile it if someone guides me on the process, as I’m too new to Kodi to do it by myself.
Best regards,
Hello,
I have additional information: I tested many previous Kodi releases over different OSs, and it’s only working on Kodi v14.
For example it works on Open Elec with the following image OpenELEC-RPi2.arm-5.0.8.img.gz
I like OSMC so I offer myself to help/test/validate on a fix, but I have no knowledge to fix it by myself.
Best regards,
