I’ve been having audio/video stuttering issue when I update the latest OSM RC version (March 14th 2015).
I just reinstall the RC version from scratch restored my kodi backup, and was all working smoothly until I downloaded the latest OSMC update which now causes any video played to stutter (both audio and video) as soon as I start playing the video and when I skip back or forward. The issue only lasts a few seconds and then it is smooth again. It didn’t however happen at all in Alpha4 or on the RC version prior to updating online.
Is this a know issue, is it being addressed on the next release?
Firmware is maintained by the Raspberry Pi Foundation, hopefully OSMC will release the new firmware soon, probably at the time that Kodi 14.2 is released for OSMC (14.2 was just released by Kodi) Note that this is all speculation and no promises are made
Also I’m not sure what specific logs file would be useful, or if I just use the log uploader withing the OSMC kodi add-on.
anyway as Dilligaf pointed out it’s probably an RPi2 firmare related issue, surely other people would have experienced the same if that’s the case though.
I just received an update today 29th March, but the issue is still there.
I’m curious to know if anybody else with Rpi2 that installed RC and has updated osmc online gets the same issue for 3 or 4 seconds when playing or skipping.
I turned update off after installing - experience has shown that updates often cause issues initially so unless something is missing/broken I tend not to update often needless to say I dont have the issue
This sounds like an issue that snuck into the Kodi branch we use.
Do you use subtitles?
If so, try disabling subtitles and see if the issue is gone.
If this is the case this has already been fixed and will be shipped in the next mediacenter (Kodi) update.
P.S: You will often have available updates as we use Debian APT and have the Jessie source. This doesn´t necessarily mean that OSMC is updating any of it´s packages, it can be something else.
Mediacenter/Kodi has not been updated in a while so that was not what you saw.
At this moment, no. There is only one version available in the repository at the moment.
Remember, you are on RC, things are still being tested.
If you dare you could try my test build from this Friday. I also use subtitles and built my own version to test.
It´s actually not dangerous at all since it uses the same versioning etc. so it will not bork any future upgrades.
And in this case you will be able to downgrade.
Oh, I forgot to mention; I believe this only affects OMXPlayer.
If this is the case (not entirely sure) you can disable OMX acceleration but keep MMAL acceleration enabled.
You do this in Settings>Video>Acceleration.
Thanks Miappa, you are exactly right, only when using subtitles the issue occurs.
And you are also right, the issue disappears even when using subtitles if the option “System->Video->Acceleration->Allow hardware acceleration (OMXPlayer)” is turned off.
Thanks a bunch for clearing this up for me.
I suppose I’ll leave OMXPlayer acceleration off until the issue is fixed in the next Kodi update.
great news that your nightlies will be back, @miappa, I’ve always used them successfully for raspbmc. by “this Friday” you actually mean the 3rd of April, right?
