Maybe somebody can help me. My OSMC remote control was working until I tried to use the OSMC remote control with a remote power plug (which can be turned off and on with any IR remote control). Since then my OSMC remote control is not working with my Vero 4K anymore. Has anybody any idea what to do (it’s not that big problem as I’m using Yatse, but would be nice if it’s working again).
I’m still not quite sure what you’re trying to do, but the OSMC Remote requires the RF dongle to operate. A long pulse (half a second) indicates the remote isn’t paired with its receiver.
I suspect if you plug the receiver back in to your Vero 4K and reboot, it will work just fine.
Sadly it seems that my dongle has stopped working, too
Last thing I did before it stopped working was a sudo halt, then unplug the Vero 4K, move it to its final place and replug it again. Since then the remote does not work anymore. The dongle has never been plugged into any other device than the Vero 4K. Also the (2-3 weeks old) battery in the remote seems to be fine as it shows a blue led for approximately half a second when i press a button.
I then reinstalled OSMC on the Vero, but no difference. I also tried to repair the remote with the dongle as suggested, on both USB ports and several times.
As you may notice, there seems to be no difference, the dongle doesn’t seem to be recognised. Is there anything else I can test before I have to send dongle/remote back to you?
I seem to have a failed USB adapter as well – sudo lsusb only shows the USB root hubs. I’d PM or email but I can’t seem to find that info, maybe it’s because I just registered and am now posting. Anyway, any help would be great.
