I don’t have an answer to that one. They should be getting picked up as regular multimedia keys but instead they are displaying as something I can’t explain…
2020-06-11 09:57:32.361 T:140414769291840 DEBUG: HandleKey: long-0 (0x100f200, obc-16838913) pressed, action is
2020-06-11 09:57:41.960 T:140414769291840 DEBUG: HandleKey: leftctrl (0xf0d0) pressed, action is
2020-06-11 09:57:41.994 T:140414769291840 DEBUG: HandleKey: ctrl-space (0x1f020) pressed, action is
2020-06-11 09:57:42.079 T:140414769291840 DEBUG: HandleKey: ctrl-leftalt (0x1f0d4) pressed, action is
2020-06-11 09:58:15.778 T:140414769291840 DEBUG: HandleKey: 0 (0xf200, obc-61697) pressed, action is
2020-06-11 09:58:25.661 T:140414769291840 DEBUG: HandleKey: leftalt (0xf0d4) pressed, action is
I think the o and long-o where probably the keys you have working now but why the others would be getting picked up as dead keys I have no answer for. On the testing in OSMC none of the languages had any issue picking up the multimedia keys so I didn’t have to change any mapping on them.
In order to work around language issues in Kodi I remapped i and c to ( and ) with udev. That osmc_classic.xml keymap just adds mapping for that with a slight tweak to make it map similar to our old remote (If they choose to disable our custom keymap). As the hwdb file posted in this thread maps directly to i and c, which line up with stock Kodi keymaps for info and context menu, that file doesn’t really do anything for you.
If you were looking to get to where you were emulating the current OSMC function the keymap you would be looking for is /usr/share/kodi/system/keymaps/osmc/osmc_remote.xml but you would not be able to load it from the same location without modifying peripherals.xml. You could just copy it to .kodi/userdata/keymaps/ and it should load.
I would guess the next step would be to run evtest and see what it reports when you press the keys that are not working. If it is reporting them as something odd then perhaps you could add them to your (I believe your saying now working) hwdb file to map them correctly. It should look something like this…
Summary
osmc@kodi_cave:~$ evtest
No device specified, trying to scan all of /dev/input/event*
Not running as root, no devices may be available.
Available devices:
/dev/input/event0: OSMC Remote Controller USB Keyboard Mouse
/dev/input/event1: OSMC Remote Controller USB Keyboard Mouse Mouse
/dev/input/event2: OSMC Remote Controller USB Keyboard Mouse Consumer Control
/dev/input/event3: OSMC Remote Controller USB Keyboard Mouse System Control
/dev/input/event4: Logitech K400
Select the device event number [0-4]: 2
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x2017 product 0x1689 version 0x110
Input device name: "OSMC Remote Controller USB Keyboard Mouse Consumer Control"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 1 (KEY_ESC)
Event code 28 (KEY_ENTER)
Event code 74 (KEY_KPMINUS)
Event code 78 (KEY_KPPLUS)
Event code 103 (KEY_UP)
Event code 105 (KEY_LEFT)
Event code 106 (KEY_RIGHT)
Event code 108 (KEY_DOWN)
Event code 110 (KEY_INSERT)
Event code 111 (KEY_DELETE)
Event code 113 (KEY_MUTE)
Event code 114 (KEY_VOLUMEDOWN)
Event code 115 (KEY_VOLUMEUP)
Event code 116 (KEY_POWER)
Event code 119 (KEY_PAUSE)
Event code 120 (KEY_SCALE)
Event code 128 (KEY_STOP)
Event code 130 (KEY_PROPS)
Event code 131 (KEY_UNDO)
Event code 133 (KEY_COPY)
Event code 134 (KEY_OPEN)
Event code 135 (KEY_PASTE)
Event code 136 (KEY_FIND)
Event code 137 (KEY_CUT)
Event code 138 (KEY_HELP)
Event code 139 (KEY_MENU)
Event code 140 (KEY_CALC)
Event code 142 (KEY_SLEEP)
Event code 144 (KEY_FILE)
Event code 150 (KEY_WWW)
Event code 152 (KEY_SCREENLOCK)
Event code 155 (KEY_MAIL)
Event code 156 (KEY_BOOKMARKS)
Event code 158 (KEY_BACK)
Event code 159 (KEY_FORWARD)
Event code 161 (KEY_EJECTCD)
Event code 163 (KEY_NEXTSONG)
Event code 164 (KEY_PLAYPAUSE)
Event code 165 (KEY_PREVIOUSSONG)
Event code 166 (KEY_STOPCD)
Event code 167 (KEY_RECORD)
Event code 168 (KEY_REWIND)
Event code 169 (KEY_PHONE)
Event code 171 (KEY_CONFIG)
Event code 172 (KEY_HOMEPAGE)
Event code 173 (KEY_REFRESH)
Event code 174 (KEY_EXIT)
Event code 176 (KEY_EDIT)
Event code 177 (KEY_SCROLLUP)
Event code 178 (KEY_SCROLLDOWN)
Event code 181 (KEY_NEW)
Event code 182 (KEY_REDO)
Event code 206 (KEY_CLOSE)
Event code 207 (KEY_PLAY)
Event code 208 (KEY_FASTFORWARD)
Event code 209 (KEY_BASSBOOST)
Event code 210 (KEY_PRINT)
Event code 212 (KEY_CAMERA)
Event code 216 (KEY_CHAT)
Event code 217 (KEY_SEARCH)
Event code 219 (KEY_FINANCE)
Event code 223 (KEY_CANCEL)
Event code 224 (KEY_BRIGHTNESSDOWN)
Event code 225 (KEY_BRIGHTNESSUP)
Event code 228 (KEY_KBDILLUMTOGGLE)
Event code 229 (KEY_KBDILLUMDOWN)
Event code 230 (KEY_KBDILLUMUP)
Event code 231 (KEY_SEND)
Event code 232 (KEY_REPLY)
Event code 233 (KEY_FORWARDMAIL)
Event code 234 (KEY_SAVE)
Event code 235 (KEY_DOCUMENTS)
Event code 240 (KEY_UNKNOWN)
Event code 241 (KEY_VIDEO_NEXT)
Event code 244 (KEY_BRIGHTNESS_ZERO)
Event code 256 (BTN_0)
Event code 353 (KEY_SELECT)
Event code 354 (KEY_GOTO)
Event code 358 (KEY_INFO)
Event code 362 (KEY_PROGRAM)
Event code 366 (KEY_PVR)
Event code 370 (KEY_SUBTITLE)
Event code 372 (KEY_ZOOM)
Event code 374 (KEY_KEYBOARD)
Event code 376 (KEY_PC)
Event code 377 (KEY_TV)
Event code 378 (KEY_TV2)
Event code 379 (KEY_VCR)
Event code 380 (KEY_VCR2)
Event code 381 (KEY_SAT)
Event code 383 (KEY_CD)
Event code 384 (KEY_TAPE)
Event code 386 (KEY_TUNER)
Event code 387 (KEY_PLAYER)
Event code 389 (KEY_DVD)
Event code 392 (KEY_AUDIO)
Event code 393 (KEY_VIDEO)
Event code 396 (KEY_MEMO)
Event code 397 (KEY_CALENDAR)
Event code 398 (KEY_RED)
Event code 399 (KEY_GREEN)
Event code 400 (KEY_YELLOW)
Event code 401 (KEY_BLUE)
Event code 402 (KEY_CHANNELUP)
Event code 403 (KEY_CHANNELDOWN)
Event code 405 (KEY_LAST)
Event code 407 (KEY_NEXT)
Event code 408 (KEY_RESTART)
Event code 409 (KEY_SLOW)
Event code 410 (KEY_SHUFFLE)
Event code 412 (KEY_PREVIOUS)
Event code 416 (KEY_VIDEOPHONE)
Event code 417 (KEY_GAMES)
Event code 418 (KEY_ZOOMIN)
Event code 419 (KEY_ZOOMOUT)
Event code 420 (KEY_ZOOMRESET)
Event code 421 (KEY_WORDPROCESSOR)
Event code 422 (KEY_EDITOR)
Event code 423 (KEY_SPREADSHEET)
Event code 424 (KEY_GRAPHICSEDITOR)
Event code 425 (KEY_PRESENTATION)
Event code 426 (KEY_DATABASE)
Event code 427 (KEY_NEWS)
Event code 428 (KEY_VOICEMAIL)
Event code 429 (KEY_ADDRESSBOOK)
Event code 430 (KEY_MESSENGER)
Event code 431 (KEY_DISPLAYTOGGLE)
Event code 432 (KEY_SPELLCHECK)
Event code 433 (KEY_LOGOFF)
Event code 439 (KEY_MEDIA_REPEAT)
Event code 442 (KEY_IMAGES)
Event code 576 (KEY_BUTTONCONFIG)
Event code 577 (KEY_TASKMANAGER)
Event code 578 (KEY_JOURNAL)
Event code 579 (KEY_CONTROLPANEL)
Event code 580 (KEY_APPSELECT)
Event code 581 (KEY_SCREENSAVER)
Event code 582 (KEY_VOICECOMMAND)
Event code 583 (?)
Event code 592 (KEY_BRIGHTNESS_MIN)
Event code 593 (KEY_BRIGHTNESS_MAX)
Event code 608 (KEY_KBDINPUTASSIST_PREV)
Event code 609 (KEY_KBDINPUTASSIST_NEXT)
Event code 610 (KEY_KBDINPUTASSIST_PREVGROUP)
Event code 611 (KEY_KBDINPUTASSIST_NEXTGROUP)
Event code 612 (KEY_KBDINPUTASSIST_ACCEPT)
Event code 613 (KEY_KBDINPUTASSIST_CANCEL)
Event type 2 (EV_REL)
Event code 6 (REL_HWHEEL)
Event type 3 (EV_ABS)
Event code 32 (ABS_VOLUME)
Value 0
Min 0
Max 896
Event type 4 (EV_MSC)
Event code 4 (MSC_SCAN)
Properties:
Testing ... (interrupt to exit)
Event: time 1592686292.603164, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0226
Event: time 1592686292.603164, type 1 (EV_KEY), code 128 (KEY_STOP), value 1
Event: time 1592686292.603164, -------------- SYN_REPORT ------------
Event: time 1592686292.619171, type 4 (EV_MSC), code 4 (MSC_SCAN), value c0226
Event: time 1592686292.619171, type 1 (EV_KEY), code 128 (KEY_STOP), value 0
Event: time 1592686292.619171, -------------- SYN_REPORT ------------
Event: time 1592686297.083142, type 4 (EV_MSC), code 4 (MSC_SCAN), value c00cd
Event: time 1592686297.083142, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 1
Event: time 1592686297.083142, -------------- SYN_REPORT ------------
Event: time 1592686297.099108, type 4 (EV_MSC), code 4 (MSC_SCAN), value c00cd
Event: time 1592686297.099108, type 1 (EV_KEY), code 164 (KEY_PLAYPAUSE), value 0
Event: time 1592686297.099108, -------------- SYN_REPORT ------------
