I’m trying to sort out what I’m doing wrong. I’ve followed the information I found in RetroPie Roms Locations OSMC - #9 by osmcnoob I created a folder /home/osmc/roms and mounted my share to it using .smbcredentials to pass authentication.
RetroPie is seeing all of my roms but will not run any of them. I can ssh into it and see the fstab mounts are working, iI can navigate them, and write a test file to them. The share has three folders, backups, media, and RetroPie. the osmc library uses the media folder and I have tested a backup they are working as expected.
The roms start the run, I see the grey splash screen about error logging and configuration but then it returns me to the main menu.l’ve looked in /dev/shm/runcommand.log and pasted it below.
Parameters:
Executing: /opt/retropie/emulators/retroarch/bin/retroarch -L /opt/retropie/libretrocores/lr-snes9x2010/snes9x2010_libretro.so --config /opt/retropie/$
PPU.RenderSub = 1
PPU.FullClipping = 1
Settings.Transparency = 1
Settings.SpeedhackGameID = 0
PPU.SFXSpeedupHack = 0
coldata_update_screen = 1
/opt/retropie/supplementary/runcommand/runcommand.sh: line 1005: 1456 Segmentation fault /opt/retropie/emulators/retroarch/bin/retroarch -L /opt$
