Hi, from the Estuary skin, I’ve switched and trying out the OSMC Skin (Vero V), which I like.
Though in the Movies menu it lists only a single row of set of films, and each catogory has to be scrolled through. is it possible for more category rows to be displayed as is the case for Estuary skin in Movies?
Sorry, I did try to search for an answer
At any given time, only one horizontal widget will be visible in the main menu of our OSMC Skin. You can however fully customize the main menu to your liking which does also include the possibility to add more than one widget to each main menu entry: [HowTo] Customize the OSMC Skin main menu
You can toggle between those widgets by selecting a widget item and then pressing the up or down key
