Well it looks like another OSMC version is here and it has finally booted from a disk image.
The Good: (compared to the Alpha4 release)
a nicely designed Splash screen with a quick bootup time.
the Skin has finally increased the size of fonts used. This badly needed fixing to be able to use OSMC from 10 feet away on the lounge. Very Welcome.
MY OSMC and the App Store works and is the interface is pretty slick.
The Live TV interface is clean and fresh. Channel switching is quick.
Incomplete at this time:
Network Settings, I’m unable to connect and pair a PS3 remote to a standard Cambridge BT USB. A reboot is even required to be able to enable it, Its not plug and play. A code should not be needed to pair this BT remote.
I could not Enable WIFI on a RT5370 USB even after a reboot.
Weather text and Artwork is misaligned, unable to even see the current Temp
in the View files mode I’m unable to bring the slider up to quickly scroll through files
lack of View mode choices in Movie Library mode, only list in present
I’m not sure what version of Kodi this is based on but I’m having a lot of issues with various files that do play properly on Kodi 14.1 on other OS platforms. The same issues with these files occurred in early versions of Kodi on other platforms as well.
Design issues with the Skin:
The white colours chosen to highlight a selected item, are confusing as hell sometimes with a Title or a Submenu item. I lose where I am and what is actually selected. Please change the highlighted item colour to a lightblue or something. Anything but white. This is really frustrating and annoying and detracts from the usability of the Skin.
In the English world we read Left to Right. Some of the Submenus present a list on the right hand side of the screen and then make a user select an action on the left. Other screens its the other way around. There appears to be no consistency, and detracts from the GUI flow.
I am unable to tell what TV Channel I am on or even what movie I’m watching when pulling up the info screen, artwork and info appear to be sorely missing.
Its a personal opinion but I ask where is the fun factor with the OSMC Skin. Ok its slick and minimal but a wee bit more bling would be nice without going over the top. As an example. In the movies Library view you can barely see the Fanart in the background.
This is supposed to be an OS Skin for a Media device. At the moment it appears to be an OS dressed in a sharp Business suit. Slick and functional, but the fun factor is missing.
Overall, a good effort.
Yes I appreciate more work needs to be done but the OSMC team have done a very nice job.
Thanks Guys.
W.
On many of the menus selected text font weight only increases slightly. It is more distinguishable on a smaller television but on a larger set for some reason the text font weight looks almost the same as the unselected text. Maybe it’s my eyes, but looks like others are experiencing it as well.
