Hi. i recently purchased a usb touchscreen for my raspberry pi 3 to use with osmc. Now osmc only recognise when i touch it and cursor shows on top left corner. But in raspbian and ubunto mate the touch screen works well. Now i want to know how can i solve it ? Can i import raspbian or ubuntu mate touchscreen drivers into osmc to get working ?
my touch screen is “ILITEK Multi-Touch-V3000” and i see this too: “from XInput”
its what i see from calibration tool in raspbian.
Ok, was just a hope. Than as Sam wrote most likely the touchscreen is driven by a X11 input driver which would not be present in OSMC as no X11 is used
Can i use raspbian kernel in osmc ? Or there is no way to import or install x11 on osmc ? Or there is no other kodi or mediacenters that i can use ? My touchscreen works well in Windows 10 too. Thanks for your reply
hi. is there anybody knows how to fix touchscreen to work with kodi ?
Basically there are only two main mediacenter distributions for the Pi. OSMC and Libreelec. Based on my knowledge both don’t use X11 so I assume both don’t support your touch screen. But feel free to checkout libreelec
thanks . i tried libreelec but wont work. there is about 5 mediacenter distributions for the Pi. xbian - opnelec - libreelec - osmc and carpi . i tried 3 of them but dont work. only raspbian and ubuntu mate worked
i just need a mediaplayer to use in my car.
my touch screen is “ILITEK Multi-Touch-V3000” “from XInput”
anybody knows anything that can help me ?
Since I don’t have the touchscreen to test with, I have no idea, and I doubt anyone else here would. If you are experimenting and tinkering, then you should be doing just that. Give Kodi a try on Raspbian and see what happens.
EDIT: It was pointed out to me that while Kodi would work, you will not get hardware acceleration for the video, so video playback probably wouldn’t work very good.
