The lastest Update process of OSMC to version 2020.10-1 destroyed other programs which were installed on the Raspberry Pi. I thought that was actually related to OpenHAB, that the program could not start after the OSMC update.
Now I have the same issue that the docker program does not start anymore after the OSMC update process. Anyone encountered similar problems? The update process seems to not work properly and interfere with installed programs.
OSMC Logs: https://paste.osmc.tv/uyidovaqal
Btw: great job for uploading the logs. That is really comfortable.
Well, I doubt if anything has been “destroyed” but it’s a great click-bait title.
Anyway, the problem is with a change introduced in Debian Buster. To fix it, you’ll need to configure your system to use iptables-legacy. Follow the instructions in this post:
Thank you very much. That actually solved the problem.
Great support in that forum.
Just for my understanding:
I was able to find out what the iptables is doing and that there was a renaming/new version. What I did not understand is: is it a lack of the OSMC system or should that be fixed within newer versions of docker? so probably I will stumble over the same setting again in the future when doing an update?
