as i upgraded osmc to the latest version - jan 2020, my conlfuence skin is not working anymore why? how can i fix it?
Also i have a movie h264 video … and i cant playback it anymore …
I was told its:
Bug in amlcodec, which is not supported anymore
it cannot cope with the h264 video you throw at it
How can i fix that bug also?
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
We haven’t had other reports of these issues, so we need information about your system to resolve it.
If it was a problem that others were experiencing, we would reproduce and resolve the issue on our side. But for now we need to learn more information about how your system is configured.
Can you please post full information using MediaInfo?
The skin version you are installing is too old. See if an updated version is available. My understanding is that there is not a Kodi v18 (Leia) compatible version. See Where to download Confluence skin (Leia).
From your log, assuming the file is “Before the Flood-Je s nami konec-Dokument Leonardo Di Caprio.avi” – it is corrupted. Remuxing the file should resolve the issue.
i do not understand:
And check for upgrade addons shows nothing. I did force install 4.5.4 from repository and it compatible with Leia.
how can i force install 4.5.4 … basically you pushed update and it breaks things down…
Regarding the file …vlc can playback it w/otut any issue, what do u mean by remux? I dont have mediainfo on my windows… isnt that full description from vlc i posted?
eneral
Complete name : C:\Users\heap\Desktop\Before the Flood-Je s nami konec-Dokument Leonardo Di Caprio.avi
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 1.36 GiB
Duration : 1 h 35 min
Overall bit rate : 2 043 kb/s
Writing application : Lavf56.25.101
Video
Format : AVC
Format profile : High@L3.1
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Codec ID : H264
Bit rate : 1 836 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.080
Stream size : 1.22 GiB (90%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : FF-2
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 131 MiB (9%)
Alignment : Split across interleaves
Interleave, duration : 23 ms (0.58 video frame)
Firstly, OSMC will never update without your permission.
Confluence is not available for Kodi Leia to my understanding. We have been shipping Kodi Leia for almost a year now. It’s possible you’ve upgraded from a very old version of OSMC, where Confluence was previously supported, but it is not supported now.
VLC is likely playing back with software acceleration. You can probably do the same under Settings -> Video -> Playback and disabling AMCodec, but this is not an ideal solution. Hardware decoders have lower tolerances than software decoders to problematic files. The file also has a variable frame rate, which is not tolerated well by hardware decoders. In short: it is a bad recording.
From which repository did you install it from?
I would suggest contacting the maintainer of that repository if it’s not from the official Kodi repository.
