Hi guys,
Im trying to setup a tvheadend server in a linux virtual machine.
I’ve tried several installs and I can’ get the device to be correctly working.
Once I’ve managed to find it but only in DVB-T. I need DVB-C.
Which version of linux should I try?
Which kernel version are you using?
Hi.
I’ve tried several virtual machines.
Ubuntu server with kernel 5.4.0-77
Debian with 4.9.0-13.
Which version can I use to have DVB-C?
The DVB-C adapter will show up as Panasonic or Sony, depending on the model.
The 5.4 kernel has everything you need for either adapter, but you may need to make sure that your kernel has the necessary configuration options enabled.
