Osmc visualization
I’d like to have the “list” as a std visualization instead of “large” or “wall”. Is there any way to set it by default on all the pages?
What skin are you using?
To get a general idea how this would work see here:
osmc
So try the solution in the link I provided,
We may add more views in the future
I tried it but without success. Nothing changes.
I think it’s because some views don’t allow list visualisation.
But I can change it using the menu on the left side. So it must be a parameter to change, but which one?
Well, while you try to figure it out here, maybe it would ve less timeconsuming to go through every list and change the view manually. I think it should stay how you set it the last time.
